Sponsored by: Real Truck
4x4 not working
Old Jan 18, 2024 | 05:09 PM
Capitolmasonry's Avatar
Capitolmasonry
Trailering
Ok I will try this tomorrow. Thank you and will let you know.
Old Jan 19, 2024 | 09:31 AM
Model a ford's Avatar
Model a ford
Is SOTF( shift on the fly) lite coming on to tell you its in 4x4 (high or low) ?
on my truck , one of the front axle u joints looked and felt good, but was actually seizing inside, steering very stiff, and would not come back to strait on its own,
replaced BOTH ujoints and wola- steering fixed.
if SOTF lite isnt coming on you have an electrical supply problem to switch and 4x4 relays. Send message here if lite is or isnt coming on.
Old Jan 19, 2024 | 09:54 AM
Capitolmasonry
Trailering
Yes light does come on. And the passenger u joint is shot. I ordered part Monday and just waiting for it to show up. I'm hoping this will fix the issue. I inspected the vacuum lines and they seem to look good. But if u joint don't fix problem then I'll go ahead and replace those too. I'm going to try jacking up one side today and see wheel spins, like what was previously mentioned on here...thanks for your input!!
Old Jan 19, 2024 | 11:32 AM
00t444e's Avatar
00t444e
It will still work with a bad U joint, just make a bunch of noise if it is bad enough.
Old Jan 26, 2025 | 11:37 AM
Capitolmasonry
Trailering
So passenger side is locking in now that I replaced hub, seals, and the u joint that was bad. Thinking the drivers side hub is bad. Going to try this next
oneharvester
Feb 25, 2008 08:14 PM
gquinn8516
Aug 7, 2005 12:55 AM
fordtruckandtractor
May 17, 2005 08:42 PM
petem
May 31, 2001 09:50 PM
