starter??
Old Jan 15, 2024 | 04:06 PM
diggerrigger's Avatar
diggerrigger
Step one: Make sure the solenoid is grounded. If the base of the solenoid is not grounded (making a good connection with body metal) it is not going to work.
Old Jan 15, 2024 | 05:02 PM
88n94's Avatar
88n94
You know I been dealing with and working on my Fords for more years than I dare say and I never knew that until I read it somewhat recently on this site. I will have to play around someday and convince myself whether or not it's true. Don't take offense for me possibly doubting you.
Old Jan 15, 2024 | 07:43 PM
FuzzFace2's Avatar
FuzzFace2
Think about it you have power into it from the battery, You have a trigger wire hooked to the S lug.
So to complete the path you have to have a ground.
Pull the 2 screws that hold it in place and hit the key and wait for ................................. nothing!
Dave ----
Old Jan 15, 2024 | 08:59 PM
88n94's Avatar
88n94
Dave ----
I hear what you are saying. I am not fully convinced that it can't ground another way. I will pull the 2 screws and see if the starter will engage. It may be a couple weeks as it isn't even getting above zero for highs here. When I find out I will post back to this thread and admit defeat.
Old Jan 16, 2024 | 11:08 AM
BigBlue2's Avatar
BigBlue2
The only other way to get to ground would be with a wire to ground. Do you think that Ford would spend money to install a wire to ground when the starter relay is already grounded?
mac01
24
Nov 27, 2009 03:01 AM
Upper
Apr 14, 2009 04:06 PM
guthrie&co
Mar 23, 2006 07:06 PM
SmittyD
Nov 9, 2004 10:22 AM
