Ok new batterys,tried to jump the relay,tried to jump the two big posts at the starter,just massive sparks.Starter is a napa that is 6 months old.Any insite would be appreciated. Upper in Clovis
Hit the starter with a hammer, then try again. But yeah, sounds like a starter, or a cable has corroded internally where you can't see it. Check all you connections from the batt terminals, all the way down.
its got to be the starter my truck did the same deal after i got a starter from napa. after hitting it with a hammer lightley (of corse) it started like 20 times after that and then it did it again and i put a new starter in the truck..
I had a problem with my starter in my 7.3 the previous owner put a cheap auto Zone reman in it an lasted 1 month ! i bought a motorcraft starter to replace it an ,,, wha la 2 years later it still starting . you pay for what you get at any of those chain stores Get the good one a little more $$ but well worth it . Good luck
Trouble shot everything to the starter and replaced it.Napa did not check or blink an eye when they replaced it,8 months old.Turns great now.Thanks again all ...........Upper
