Headlight problems!
Old Jan 14, 2024 | 01:40 PM
Tooldude1984's Avatar
Tooldude1984
1st Gear
Headlight problems!
Hello, greetings!
I’m a new member!
Hopefully, you can be of help.
Let me explain. My 1990 Ford f150 4.9 2wd is having some issues.
She only has one good light, the front left signal light. All the other are “no bueno.”
What I’ve done: bought new headlight, (figured a one in a million chance all other lights dying at the same time occurred). Problem not solved!
I also checked the wiring all looked good.
please share any insight or hunch! Many thanks and happy Sunday!
Old Jan 14, 2024 | 02:06 PM
jas88's Avatar
jas88
Your title says "headlight problems". But then you say you have only one good "signal light". Please take the time to explain the problem better what is working and what is not.
Old Jan 14, 2024 | 02:27 PM
jwitty's Avatar
jwitty
Check the switch?
Old Jan 14, 2024 | 03:22 PM
Edgethis's Avatar
Edgethis
Both other members have mentioned some great tips to help us help you.
I really would check into the light switch, pretty much all the trucks lighting goes through there. Also, make sure the fuses are all good.
Did this issue happen suddenly? Driving fine and then "Bam!" No lights?
Old Jan 15, 2024 | 04:41 AM
manicmechanic007's Avatar
manicmechanic007
Verify the right bulbs are in the sockets (one terminal vs 2 terminals)
Then verify power (and ground) to the sockets as the lights are on or supposed to be flashing
The headlight switches are cheap, have one handy to plug in for diagnosis (a used one works for testing)
The sockets melt and fail, wrong bulbs create feedback and blown fuses sometimes
Black Ford XLT
Dec 21, 2016 11:03 AM
BlueOvalFan29
2004 - 2008 F150
Aug 24, 2010 02:04 AM
kc 300EX
Jul 1, 2010 07:30 PM
kramer56
1997 - 2003 F150
Nov 18, 2006 12:11 PM
