I bought my 19 FX4 F250 used in July. I’ve thought since I bought it it was fairly rough. Deff more rough than my F150 was. I brought it up in a couple threads and people just said I was expecting a car like F150 ride in this truck. I’m getting more used to it.
I feel like in my case it’s the springs. I don’t think it’s too firm. I think it’s more the rebound action of the rear springs when going over bumps. Because as soon as I get 400-500 lb in the bed it rides so much better which is just enough weight to slow down the bouncy rebound of the rear springs.
not sure a new shock would damper the rate of that rebound or not. I only drove one other used truck before buying this one and don’t remember er how it rode.
thought about the solastic shackles but it’s a good expense to eat.
also thought about one of those carry water bags you can get. You can fill them with like 75 gallons of water which would add around 500 lb. And just let it ride around in the bed of the truck.
You can substantially reduce the bounciness by lowering your tire pressure. However, you'll have to adjust the TPMS min and max values in the ECM (using ForScan, e.g.).
If you're unloaded or not towing, you can reduce the rears to 40 - 45, and the fronts to 50 - 55 psi, and the difference is very noticeable. I only air back up when I know I'm going to haul a load or tow the trailer.
Is your friend's F350 loaded with weight when you tested it? Your F250 will ride a lot better with a few hundred pounds in the bed to weigh down the springs a bit. Otherwise if all conditions are the same including load, shock condition, tire pressure, etc, it would be very strange to have an F350 that rides significantly better than an F250 of same era and similar set up.
Yep, does the OP's friends F350 have the same engine? load? wheelbase? Tire pressure will help. Shocks are different 4x4 vs. FX4 but I doubt it makes a significant difference in ride....
Has anyone looked at the part numbers of the FX4 shocks and the 4x4 shocks? This should at least be an indicator whether they are the same or not.
As Bruski pointed out, not the same part. I also haven't claimed they are the same shock. That doesn't however mean that they offer a drastically different ride or take away from the fact that they are both budget OE shocks. The difference in ride between the FX4 and standard shocks would not be the difference between riding like a dump truck and riding like a dream. No shock alone will make that kind of ride transformation....unless the existing shocks have failed in some way.
factory shock are junk. they don't do anything. Remove one to try out. You can push it in and it won't push the other half back out. Matter of fact., you can push and pull apart by hand. I replaced the factory shocks on my 2021 F350 DRW FX4 Lariat Ultimate as soon as I drove off the lot with Bilstein 5100 series. You'll notice the improvement right away
2021 Fx4 lariat compared to 2021 fx4 King Ranch. Noticeable difference in ride. The Lariat had been upgraded to Bilstein 5100s and the Roadmaster system. Both were major improvements over a stock setup on on the Lariat. Vehicle replaced after being totaled with 2021 King Ranch that has slightly oversized tires and front levelling. It rides much smoother than the Lariat with its upgrades. But my guess would be the King Ranch probably has the same shocks the fx4 had initially, unless Ford does upgrade the KR in that area as well. Perhaps the KR with diesel and its weight difference impacts ride over the Lariat with the 7.3 as well. Currently running the oversized tires on the KR at 55 front/60 rear per Falken tech support recommendations.
I don’t get it. I love the bumpy / rough ride of the super duty. My 08 with the snowplow prep and 35’s with 70 psi rode amazing. My 2024 rides way too soft comparatively. Can’t wait to get bigger heavier tires on the new truck.
someone doesn't know how a standard (non gas charged) shock is supposed to function
I know everyone is talking about the shock's between the FX4 and 4x4 package but could the spring rate be different between the packages?? I have read in the FX4 package it states "Enhanced Suspension" Just wondering.
"Enhanced suspension" is their "off-road tuned" shocks. It is fraud at the least. The shocks are trash and need replaced shortly after the springs settle.
Everyone says the stock shocks are trash!!! I don’t get it! Some people just love wasting money on their already way overpriced trucks!
The value of any item is subjective. If the person paying for that item gets some kind of enjoyment, or perceived improvement from it, is that really a waste of money? People have been modifying and "upgrading" automobiles, for better or worse, longer than I've been alive. It's hard to really say something is a waste of money just because you or I don't understand it. It might be a waste for you, but not for them. I think the applicable saying is, to each their own.
Some people call the OE shocks trash because they actually experienced failure in short time, others can feel a notable difference or improvement in ride characteristics between cheap OE shocks and a quality aftermarket shock.
I could be wrong, but wasn't this thread started because you felt the stock shocks might be contributing to a trash ride?
As I've said many times....to each their own, I don't agree..
