Fx4 Package vs 4x4
Old Jan 14, 2024 | 08:30 AM
Joe T's Avatar
Joe T
What is your front GAWR and motor option? The gawr is on the white door jamb sticker.
Old Jan 14, 2024 | 08:48 AM
speakerfritz's Avatar
speakerfritz
Sulastic springs
their are two versions..regular and heavy duty
the hd has a lever you can throw if your going to tow super heavy
Old Jan 14, 2024 | 08:49 AM
Bigredtoy's Avatar
Bigredtoy
Originally Posted by FishRanger
I ordered my 2020 without the FX4 package mainly to gain some payload capacity. I'm not sure if it was enough to matter though. Anyway, before it came in I had a set of Fox 2.0 shocks waiting for it. The only driving it got on the stock shocks was about 40 miles. I really can't tell you if there was a difference in ride with the shock change but I do know that my long bed rides very comfortably for a big truck. We have taken it on several long trips without the fifth wheel behind it. Three of those trips were over 1600 miles each. My wife is pretty particular when it comes to comfort in a vehicle and she has no complaints if I say let's take the truck instead of her Subaru Ascent. I never adjust the tire pressure.
That tells me the shocks MUST be what's making the differance as my friends F-350..heavier duty than my F-250 rides fantastic. Without the FX4 package also rides like a dream.
Joe T's Avatar
Joe T
Your shocks could also be blown out.
Old Jan 14, 2024 | 08:50 AM
Bigredtoy's Avatar
Bigredtoy
Originally Posted by speakerfritz
Sulastic springs
Very interesting!
Old Jan 14, 2024 | 08:55 AM
Rhizzlebop's Avatar
Rhizzlebop
Sulastic springs
never heard of their being two versions of this. But is it a spring or are we talking about the solastic shackles? I’ve considered these. Is that what there are two versions of?
Old Jan 14, 2024 | 09:19 AM
HST's Avatar
HST
They use the same shocks on the trucks for 4x4 & FX4. it's usually the unloaded tire pressure that make the difference.
Old Jan 14, 2024 | 09:54 AM
speakerfritz
hd version
models vary
Old Jan 14, 2024 | 11:40 AM
chadstickpoindexter's Avatar
chadstickpoindexter
Originally Posted by Poncho450
One thing I haven't seen mentioned by those who air down into the 50's. Do you get the low tire pressure warning? I once adjusted the tire pressure warning threshold in on a previous Super Duty with FORScan. I don't recall doing it on my current truck. I normally run 5 psi or so below the recommended and it doesn't set off the TPMS.
Mine are set to about 55 each. However, in the cold that drops. This morning when I left for church all 4 read 51psi. The only time my light has come on has been when one has dipped into the 40’s.
Old Jan 14, 2024 | 11:54 AM
camperfanatic01's Avatar
camperfanatic01
I had a 20 F-250 fx4 and updated to a 2024 f-250 and the ride is night and day difference, I attribute this to the 2020 tires being stiffer, as I don’t think they changed the suspension that much, could be wrong though. Both came with snow plow prep and the 2024 actually has the higher rating 10,500 springs in the rear.
Old Jan 14, 2024 | 12:14 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by camperfanatic01
I had a 20 F-250 fx4 and updated to a 2024 f-250 and the ride is night and day difference, I attribute this to the 20 tires being stiffer, as I don’t think they changed the suspension that much, could be wrong though. Both came with snow plow prep and the 24 actually as the higher rating 10,500 springs in the rear.
I've read quite a few owners comment that their 23/24 rides better than their previous truck. Being that the 20" tire has larger diameter than the 18" makes the sidewall difference very small. It's only about. 5" difference in sidewall height. I wouldn't expect to notice a night and day ride difference from that.
I don't think the rating has changed in the rear, just the GVWR has gone up.
Old Jan 14, 2024 | 12:22 PM
camperfanatic01
my 2020 was rated At 10,000 gvwr, and the 24 at 10,500 (has the wider springs and a helper spring), both trucks have the same size 18” tires, 2020 having the wrangler with Kevlar and 2024 having Bridgestone Duelers At, both trucks are XLTs.
have yet to tow with the 2024, so not sure how stiff the sidewalls of the Bridgestone’s are, hoping it tows just as good (sway).
Old Jan 14, 2024 | 12:23 PM
  #28
4wd6.7L's Avatar
4wd6.7L
Yep, it's possible. I know the OP is really pushing for it to be the difference between FX4 vs 4x4 shock, but I really don't believe the difference is there.
Old Jan 14, 2024 | 12:26 PM
  #29
4wd6.7L's Avatar
4wd6.7L
my 20 was rated At 10,000 gvwr, and the 24 at 10,500 (has the wider springs and a helper spring), both trucks have the same size 18” tires, 20 having the wrangler with Kevlar and 24 having Bridgestone Duelers At, both trucks are XLTs.
have yet to tow with the 24, so not sure how stiff the sidewalls of the Bridgestone’s are, hoping it tows just as good (sway).
Oh, I completely misunderstood what you were saying. Looked like you were saying you attribute the ride improvement between your 2 trucks to be from difference in tire size. I see now that "20 tire" meant year of the truck and not tire size haha.
Yeah, I'm not sure what it is about the new trucks that has owners commenting on them having a noticeably better ride. In your case it sounds like you came from a similar optioned truck but with even lighter spring rate(rear) and still experienced a big improvement.
Old Jan 14, 2024 | 12:31 PM
  #30
camperfanatic01
sorry, totally could have worded that better.
