Starter doesn't even click
Old Jan 13, 2024 | 12:56 PM
Ford.Dude's Avatar
Ford.Dude
Tried to fire the truck up and the starter won't even click like it has dead batteries. This issue is similar to a vehicle that is stuck in between park and reverse.
No codes
Batteries are 12.**V
Does the normal injector clicking
Did notice the steering wheel doesn't go to the lock position when turning with the vehicle off and in park position
The gear position needle is off a bit and I've always had to push the shifter up a little to get it to go all the way to park..
Old Jan 13, 2024 | 01:25 PM
Jokester00's Avatar
Jokester00
No codes
Will the starter turn over if you disconnect the excite wire and put it to the positive battery post of the passenger battery? If that does turn the engine over, will it start if you put it in Neutral?
-jokester
Old Jan 13, 2024 | 01:42 PM
Ford.Dude's Avatar
Ford.Dude
Did the excite wire and the truck did turn over. Didn't try it in neutral yet. The batteries may be dropping due to cycling the glow plugs multiple times.
Relieved it was cranking as normal. Previously, via key I couldn't get a click from the starter solenoid.
Thank you so much jokester
Old Jan 13, 2024 | 01:51 PM
Ford.Dude's Avatar
Ford.Dude
It's below freezing and batteries are less than 12v at the moment. Going to plug the block heater in and charge the batteries then continue troubleshooting. The gear indicator is a little more off then usual
Old Jan 13, 2024 | 04:52 PM
kbeefy's Avatar
kbeefy
It sounds like ignition switch/interlock issues.
Old Jan 13, 2024 | 06:47 PM
DanielT28's Avatar
DanielT28
Our excursion just did the same thing, but it was the starter
Old Jan 13, 2024 | 10:12 PM
Ford.Dude's Avatar
Ford.Dude
Batteries aren't taking a charge. Pulling them in the morning and getting them tested.
Old Jan 14, 2024 | 06:11 AM
Baylinerchuck's Avatar
Baylinerchuck
The starter was just proven to be good by jumping 12v into the solenoid.
Old Jan 14, 2024 | 01:37 PM
Ford.Dude's Avatar
Ford.Dude
Bad batteries again. This time they made it about 3 months past warranty.
Sorry for the stupid thread. When the batteries show 12+v I seem to think they are still good so I assume something is horribly wrong. This truck does crazy crap when it doesn't like it's batteries and it's never gradual. 11* outside and fired right up with fresh batteries.
Thanks yall
Old Jan 14, 2024 | 01:41 PM
kbeefy's Avatar
kbeefy
Thanks for following up.
I consider 12.5 a serviceable battery if it passes a capacity test.
12.3 is end of life and 12.0 is dead.
Old Jan 15, 2024 | 11:47 AM
Jokester00's Avatar
Jokester00
Ahhh...the ole' bad battery strikes again!!
Low system voltage makes this truck do stupid things!
If you haven't been monitoring your truck's important parameters daily, this would be a hack of a good reason to start now...
-jokester
Old Jan 15, 2024 | 11:58 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Nope, always instantaneously! One slow crank and I drive straight to the Autozone for new batteries If I don't they'll be dead the next time I try to start it.
hwoolsey
13
Jul 2, 2020 01:50 AM
TowsonX
May 31, 2017 07:55 PM
KShults
Oct 4, 2016 07:40 AM
02X72
Oct 29, 2012 04:23 PM
ottawaair
1997 - 2003 F150
Aug 22, 2011 11:00 PM
