239 running hot
Old Jan 11, 2024 | 04:39 PM
mtflat's Avatar
mtflat
Keep in mind the right side runs a little warmer than the left for some reason so you may see a temp difference of up to 10 deg between the two.
Also the stock temp gauge only gives a rough idea of the actual temperature.
Anytime I have the system drained and refilled, I can count on mine showing HOT (on the gauge) before everything equalizes. That's just normal for mine.
Old Jan 11, 2024 | 05:43 PM
Matt1966's Avatar
Matt1966
Yes, it could be a problem with the temperature sensors but I think it was strange I had significant difference in temperature between PS and DS. PS upper pipes and hoses were almost cold? I will buy a temperature gun and see what temperature I got when gauge show "hot". Thanks once again!!!!!
Old Jan 12, 2024 | 08:20 AM
DieselDog409's Avatar
DieselDog409
so i dont misinform our friend here someone else explain the washer as a thermostat thing to him for me so i dont get yelled at.
Old Jan 12, 2024 | 12:01 PM
52 Merc's Avatar
52 Merc
If your hoses were cold, that definitely indicates a non opening thermostat if the other side was warm and the engine was up to operating temperature.
Old Jan 26, 2024 | 01:19 PM
Matt1966's Avatar
Matt1966
I want to thank you all for suggestions with my cooling issues. I finally got my thermostats (160 deg) but with the wrong gaskets. Had to go to "town" for some gasket material and tools to punch the holes for gaskets ( Sorry, dont know english word for this tool) I also bought an infrared temperature gun to check temperature both sides when starting it up. Truck dont runs hot anymore and both thermostats opens. DS thermostat opens a little before PS but not a lot. The temp gauge shows a little high before the thermostats opens but using my temperature gun it looks like engine is about 165 deg around the thermostat housing. For the first time in months ( thanks to you guys) I have both cooling and charging on my truck!!!!!!
Mats Nilsson, Sweden
Old Jan 26, 2024 | 03:06 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Great to hear! Glad you found out little corner of the internet and got things sorted out resulting in a running truck!
Old Jan 26, 2024 | 03:17 PM
abe's Avatar
abe
Mats, that's good news. Thanks for letting us know. I'm glad you figured it out.
your truck looks nice. Post more pictures.
I think the word you're looking for is "hole punch."
I like your gun rack!
Old Jan 26, 2024 | 04:29 PM
Matt1966's Avatar
Matt1966
Yes, hole punch it is. Thanks!!!! I promise better pictures in daylight when the snow is gone! Thanks a lot!!!!!!
Old Jan 26, 2024 | 06:12 PM
abe's Avatar
abe
That looks great Mats. That will hold us over until spring... whenever that is for you way up there.
Old Jan 26, 2024 | 06:13 PM
52 Merc's Avatar
52 Merc
Absolutely beautiful!
GUYDON
13
Jan 11, 2024 12:33 PM
VENTUREMAN
Dec 9, 2008 12:47 PM
M998
Mar 24, 2008 10:45 AM
fish-albuq
Sep 10, 2007 12:21 AM
mbone75
Jul 21, 2006 12:05 AM
