Speedo Sensor Wierdness
Old Jan 10, 2024 | 04:33 PM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by Matthew 300-6
Mine is designed differently than what you've posted AuroraGirl. Your Speed sensor mounts directly to the casting. The speed sensor on my tranny mounts first into a black plastic housing that itself sits in the casting of the transfer case. Where the tip of the yellow arrow is on my pic above is the seam between the plastic "housing" and the transfer case itself.
hmm I thought it was different. weird.
Old Jan 10, 2024 | 04:40 PM
AuroraGirl's Avatar
AuroraGirl
Old Jan 16, 2024 | 07:05 PM
Matthew 300-6's Avatar
Matthew 300-6
No one has a picture of this?
Old Jan 16, 2024 | 07:59 PM
Marsh90250's Avatar
Marsh90250
Do you know what kind of transfer case you have? There are two main types, the Borg Warner 1356 fixed yoke or slip yolk, and there is a Borg Warner 1345, rla2005 showed you a picture of his BW1356 Fixed Yoke, mine is similar to his: BW1356 Slip Yoke.
I looked online at some BW1345's for the 1988-1991 trucks and could not find any with the plastic bushing like yours.
If you post another picture of your transfer case try and get the whole thing so i can help you identify what you have. Also while your down there look for a little metal tag, should be attached to one of the bolts that holds the transfer case together. If you can't find it, no big deal.
You could try to remove that piece of conduit and do some fab work, try grinding the sides down and and bending it a bit so the conduit slides into the hole on the bracket for the speed sensor. It's not a perfect fix but It should stop it from spinning: good enough till we figure out what flavor of drivetrain you got from FORD.
Cheers!
bwiday
Mar 24, 2012 09:59 AM
SICKANDTWYSTED
Apr 4, 2008 06:31 PM
herreraxto
1983 - 2012 Ranger & B-Series
Sep 15, 2007 12:03 AM
nanufree
Dec 19, 2005 12:33 PM
