Sponsored by: Real Truck
speed sensor snapped
Old Mar 22, 2012 | 08:59 PM
bwiday's Avatar
bwiday
I was changing out the rear tow/haul speed sensor on my 2005 F250 on top of the tranny and it snapped leaving the stem of the sensor in the tranny!! Any way to retrieve the stem from the tranny w/o dropping the tranny? Thinking of drilling a hole thru the floor if need be. Truck has 100K and it rot in my driveway.
Any help is much appreciated!!
Old Mar 23, 2012 | 03:40 AM
2004 Ford F-250 v-10's Avatar
On my 04 there is an access panel under rug on drivers side hump, not sure if you will be able to reach the sensor or not, but there should be a hole there.
Old Mar 23, 2012 | 03:00 PM
bwiday's Avatar
bwiday
Thanks! I'll take a look.
Old Mar 23, 2012 | 04:52 PM
1973Ford2004's Avatar
1973Ford2004
The other thing I would do is spray a little bit of WD-40 on the sensor and twist it back and forth, let it sit and work in, I replaced that one on my 4R100 not a fun spot.
Old Mar 24, 2012 | 09:59 AM
bwiday's Avatar
bwiday
Wish I could spin it back and forth. Nothing to grab on to unfortunately. I did fill it with WD40. I'll probably drill through the floor so I can get at it from above.
Thanks for the response. Any advice can only help
emict
Nov 20, 2024 10:47 AM
1973Ford2004
Jul 7, 2011 01:56 PM
usmccope
1983 - 2012 Ranger & B-Series
Nov 18, 2009 05:15 PM
fordbabe0014
Dec 18, 2005 12:34 PM
Alby
Jan 14, 2005 04:20 PM
