Sponsored by: Real Truck
2013 F350 SMOG problem
Old Jan 9, 2024 | 11:59 AM
LagorioBrothers's Avatar
LagorioBrothers
Trailering
Hello All,
Ok, we have a 2013 F350 with the 6.7l PSD. It won't pass smog because one of the exhaust temperature sensors isn't working. I fired up AE and checked the four sensors. Sensors 1 through 3 are all giving me voltage and temperature readings. Sensor 4 is giving me voltage readings but not temperature. I tested all four sensors and they all came back with 209 to 213 ohms resistance. The voltage readings when running on all four temp sensors are between 1.02 and 1.15 volts.
I swapped sensor three and four and tried again. Still no temperature readings on sensor location number 4. Having swapped the sensors, I know it's not the sensor because the problem did not follow the sensor. I don't see any harness damage. I see a sensor controller on the passenger frame rail, # DC3A-5K202-AC. Do the temperature sensors run through the sensor controller? So any ideas guys? Thanks, Bruce
Old Jan 9, 2024 | 04:45 PM
projectSHO89's Avatar
projectSHO89
Are you getting a fault code? If so, what is it?
No, all four EGT sensors go to their respective connector pins into the PCM. You're probably looking at a NOX sensor module.
Old Jan 9, 2024 | 05:34 PM
LagorioBrothers
Trailering
No DTC's. Sorry, I should have stated that in my first post. Yes, there are NOX sensor modules, two of them I believe. So maybe a bad connector pin at the PCM? Thanks, Bruce
Old Jan 9, 2024 | 06:57 PM
projectSHO89
If you're not getting any fault codes, why do you believe you have an issue with the EGT sensors?
Old Jan 10, 2024 | 09:12 AM
LagorioBrothers
Trailering
Because it keeps failing smog tests due to one of the sensors not sending data. I used my laptop with Auto Engenuity and I get temp readings from the first three sensors but not the last sensor. So, Bank 1 Sensor 4 is not reading temps. I took that sensor and swapped it into a different spot. The problem did NOT follow the sensor. The problem stayed with Bank 1 Sensor 4. So I either have a harness, electrical pin, or PCM issue as far as I can tell. This truck is on it's third engine. Both engine changes were done by a Ford dealer. Not that that makes their work full proof because it doesn't.
So, I am asking help from the forum as to what else to look for. Thank you guys very much. Bruce
Old Jan 10, 2024 | 09:32 AM
projectSHO89
If the sensor is providing the correct voltage to the PCM for the temperature it's exposed to as you indicated in your first post, you don't have a sensor input problem. More likely, you have a software problem with AE not interpreting it correctly and also displaying a temperature value. I'd suggest a different scan device or software package like Forscan, if your OBDII interface supports it.
What is the exact monitor that is failing to complete?
Old Jan 10, 2024 | 09:36 AM
LagorioBrothers
Trailering
I do have forescan, but my OBD2 interface does not support it. So I guess I need to get the correct interface.
I don't have the sheet in front of me right now to give that info. I will get it today and update this thread with that data. Thank you, Bruce
Old Jul 8, 2024 | 09:10 AM
LagorioBrothers
Trailering
Late up date. Turned out to be a PCM issue. Got it replaced and re-flashed by Ford dealer. Issues gone now and passed SMOG. Thanks guys. Bruce
chrism
Modular V10 (6.8l)
Mar 20, 2008 10:49 PM
jemini
16
Nov 19, 2007 04:14 PM
Jeff_G
1983 - 2012 Ranger & B-Series
Aug 12, 2006 05:47 AM
mvimpvm
Jun 23, 2004 10:01 PM
bobs 93 X
13
Sep 27, 2003 10:18 PM
