2017 F350 Factory Door Keypad Code
Old Jan 9, 2024 | 11:16 AM
mcco's Avatar
mcco
4wd Low
Bought a 2017 F350 and it did not have the manual, which contains the factory door code. My dealer told me there was a sticker in the passenger foot well that I could find and would have the code. But not having any luck. Any ideas where this is?
Old Jan 9, 2024 | 11:28 AM
WXboy's Avatar
WXboy
If you have both keys, you can find the code easily by displaying it on the dash cluster.
Old Jan 9, 2024 | 11:31 AM
mcco's Avatar
mcco
4wd Low
I have both keys. What's the process to display the code?
Old Jan 9, 2024 | 11:42 AM
pete6114's Avatar
pete6114
code can be found some times inside the inside fuse box cover. if not there, take a look under the engine compartment fuse box cover too....if need be, the dealer can pull it up. didnt get that credit card size card with the truck? inside the ownership manual cover/sleeve or laying around loose the the glove compartment/s. Found this for you:
Old Jan 9, 2024 | 11:46 AM
GetMore's Avatar
GetMore
This is not really helpful, sorry. If you check the owner's manual (should be able to find it online) it should have instructions on how to use the two keys method.
Old Jan 9, 2024 | 11:47 AM
pete6114's Avatar
pete6114
how? never heard of this. Interesting....
Old Jan 9, 2024 | 11:48 AM
mcco's Avatar
mcco
4wd Low
I’ll check that out after work today. Nope. No card or owners manual. The previous owner must have kept it.
Old Jan 9, 2024 | 11:51 AM
mcco's Avatar
mcco
4wd Low
I found this for the “bladed” keys. Unfortunately this truck is push button.
https://www.ford.com/support/how-tos...th-smart-keys/
Old Jan 9, 2024 | 11:53 AM
pete6114's Avatar
pete6114
Check this out. This the what the guy above was talking about. Easier way than the link i posted above with both fobs.
Old Jan 9, 2024 | 12:05 PM
mcco's Avatar
mcco
4wd Low
Check this out. This the what the guy above was talking about. Easier way than the link i posted above with both fobs.https://www.youtube.com/watch?v=LH5iNkyhrsk
man yeah! That was it!!
thanks Pete.
Old Jan 10, 2024 | 08:28 AM
HarveyTruck's Avatar
HarveyTruck
Sounds like you got it. Mine was in the passenger kick panel, removed the access cover and there’s a spot it clips into.
Old Jan 10, 2024 | 08:50 AM
mcco's Avatar
mcco
4wd Low
that's probably what the dealer was trying to point me towards
Synless1
2015 - 2020 F150
22
Aug 26, 2024 07:19 PM
Dalton09
Jan 31, 2023 05:19 PM
Eskinny
6.4L Power Stroke Diesel
Jun 12, 2011 10:09 PM
zss42002
Dec 1, 2007 06:29 AM
BgBckHntr
Feb 8, 2004 01:46 PM
