Sponsored by: Real Truck
Steering box rebuild kit
Old Jan 8, 2024 | 03:30 PM
John W. Wythe's Avatar
John W. Wythe
6th Gear
How do I make sure I get the correct rebuild kit for my F-250 Super Duty 4x4 steering box?
Old Jan 9, 2024 | 12:05 AM
ifrythings's Avatar
ifrythings
The only way is to either count the splines on your current gear box which isn’t easy to do with the pitman arm on or if you have a vernier caliper you can measure the sector shaft size, 33.27mm/1.31” is a 32 spline and 34.93mm/1.38” is 36 spline.
Is this for your 2000 F250? Do note that there isn’t any actual rebuild kits out there, only reseal kits, if your box is leaking and is good other wise then a reseal will work, if your box is super loose or not turning one direction the “rebuild” kits won’t do anything.
jcmartindale
Apr 20, 2016 12:10 AM
zakk
May 8, 2011 07:20 PM
cbfomoco
20
Apr 26, 2011 12:47 AM
66 POJ
Jan 23, 2007 12:52 AM
