Hydra chip uninstall
Old Jan 5, 2024 | 10:33 PM
hpcbmw's Avatar
hpcbmw
I have to uninstall the hydra chip in my 2000 F250 for a few weeks. After removing the key and disconnecting both batteries to avoid shorting out the CPU, can I just pop the chip out of the circuit board? I cut a pretty good sized hole in the plastic cover, so I think I can cut out the duct tape i have holding the chip in, and then slide it out without having to remove the whole cpu. Is it that easy?
Thanks
Old Jan 6, 2024 | 12:50 AM
John in OkieLand's Avatar
John in OkieLand
you Must put the Hydra in 00 before you do anything, okay?
that sets everything back to Stock.
just unplug the USB cord, and pull the chipset out of the PCM.
Please, ground your hands on the PCM case first, then try to not touch any electrical parts.
pull it out, replace the PCM.
and start it up.
Old Jan 6, 2024 | 05:23 AM
RacinJasonWV's Avatar
RacinJasonWV
You do not need to set the Hydra to “00” before removal. The tunes are stored on the chip.
It’s as simple as you have stated. I don’t even disconnect the batteries, but do make darn sure the keys are not in the truck. (Key on condition can kill things).
Nothing wrong with disconnecting the batteries for peace on mind though.
Old Jan 6, 2024 | 03:57 PM
hpcbmw's Avatar
hpcbmw
Thanks guys! Easy chip removal has been completed.
Crewcab Turbo
Aug 31, 2012 08:58 PM
jt1080
Computer Chips & Tuners
Feb 15, 2011 08:37 PM
tony mathers
Sep 11, 2007 01:14 PM
RustyWallace
Nov 16, 2003 11:24 AM
Scortty 45
Aug 15, 2003 12:45 PM
