Will it fit?
Old Jan 5, 2024 | 09:21 AM
ynot321AB's Avatar
ynot321AB
Will it fit?
Will the heads from a 1950 239 fir on a 1948 239? Also can someone give me where the shorter head bolts go on the head, I have about 10 short ones and the rest are longer. Thanks in advance for the assistance.
Old Jan 5, 2024 | 09:25 AM
52 Merc's Avatar
52 Merc
When you say a 48 239, are you talking about a 48 truck 8BA type flathead, or the earlier style 59AB with the bell housing cast in? Those had different water passages and have different heads.
Old Jan 5, 2024 | 10:04 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
As Merc says, ensure you are using the correct head for the block. The 59A heads have the water ports in the middle, the 8BA block in the front.
As for which bolt lengths go where, I believe you can use the simple workbench trick of dropping the bolts in and ensuring they all protrude from the bottom of the head the same amount - then you know you have all the right length bolts in all the right places.
Old Jan 5, 2024 | 11:38 AM
ynot321AB's Avatar
ynot321AB
The pictures he sent show a bolt on bell housing and he is not sure of the year of the motor. Also do you know of the placement of the head bolts?
Old Jan 5, 2024 | 11:39 AM
ynot321AB's Avatar
ynot321AB
Thank you for the info
Old Jan 5, 2024 | 11:46 AM
52 Merc's Avatar
52 Merc
Can you share those pics?
Old Jan 5, 2024 | 12:37 PM
ynot321AB's Avatar
ynot321AB
I can try to send the pics, I made the mistake of buying a chrome book and haven't figured it out yet
Old Jan 5, 2024 | 12:49 PM
ynot321AB's Avatar
ynot321AB
Gonna take a 3# hammer to chrome, everytime I try to post a pic it says invalid file
Old Jan 5, 2024 | 01:44 PM
ynot321AB's Avatar
ynot321AB
I figured out how to make the [ics jpeg but still says invalid format, what format does chrome take besides hammer?
Old Jan 6, 2024 | 02:21 AM
mtflat's Avatar
mtflat
Generally, yes the 50 heads will swap to 48 8BA/8RT engine.
The head bolts pretty well sort themselves out. I can't from memory tell you which goes where, but.... The head tends to be thicker on one side - that's where the longest bolts go. Put the head on and drop in the bolts so the bolt heads sit about the same amount above their mounting boss, and you have it.
agronomistont
Oct 24, 2010 10:10 PM
familyman65
Flathead V8 & Flathead 6
Jul 2, 2009 06:58 PM
David85
43
Feb 7, 2008 11:14 PM
lisagoud
Aug 26, 2005 06:07 PM
azhuntr
Dec 12, 2003 04:19 PM
