95 F150 missing/hitching issues
Old Jan 3, 2024 | 10:35 PM
'95nick's Avatar
'95nick
2nd Gear
Question 95 F150 missing/hitching issues
I have a 95 F150 5.0. While I am cruising down the road between 35-50, it feels like its missing/hitching is the best way I could describe it. It only does this while cruising between those speeds, it doesn't do it during acceleration or if I am going 55+/down the highway. I have also noticed it won't do it while totally cold, it tends to start doing after I have driven about 5 miles.
Initially I thought it was EGR related, so I changed the EGR valve, position sensor and control solenoid. My next idea was the TPS. But prior to doing that I got a code reader. During key on engine off I had codes 157, 158 and 327. During engine on I had 225.
Codes 157 and 158 are MAF sensor related, is it possible a bad MAF would cause these issues? Want to get the diagnostics right before I keep throwing parts at it. My check engine light does work, but it never came on despite these codes being there.
Old Jan 4, 2024 | 12:32 AM
Prototypemech's Avatar
Prototypemech
Check your fuel pressure. Here's how.
https://www.ford-trucks.com/forums/1...rd-trucks.html
Old Jan 4, 2024 | 12:50 AM
'95nick's Avatar
'95nick
2nd Gear
Prototypemech;21086448]Check your fuel pressure. Here's how.
Thank you! I will test this before going any further.
Perry03
Dec 29, 2014 07:50 AM
wakum6
Nov 30, 2014 06:02 PM
daddygreenjeans13
28
Apr 5, 2013 08:58 PM
bobbyt89
Apr 13, 2010 06:53 AM
marragtop
Mar 18, 2008 09:54 AM
