Check engine light diagnosis.
Old Nov 30, 2014 | 02:25 PM
wakum6's Avatar
wakum6
So I've been getting a check engine light every once in awhile on my 94 F150 5.0. I ran a engine off key on test and got 3 codes:
176 Oxygen sensor not switching- system is/was lean left or front oxygen sensor.
177 Oxygen sensor not switching- system is/was rich left or front oxygen sensor.
327 EGR feedback signal is/was low.
The first 2 seem connected since they're completely conflicting codes but I don't know where to start troubleshooting. The EGR I have no idea about. I recently replaced the EGR sensor so maybe the EGR itself is bad? Also I'm thinking the cold weather may have some sort of effect on at least one of these issues. The CEL only used to come on intermittently in the early morning then go away. Now with temps below freezing it'll come on and stay on. Any advice?
Old Nov 30, 2014 | 06:02 PM
rla2005's Avatar
rla2005
Codes 176 and 177 are only from historical (CM) memory. Code 327 can be displayed during the KOEO tests, CM display or KOER tests. I suspect you read it during the CM display.
Clear the codes then drive the truck again. See if any of the codes return. If they do, check for codes then list them here by number and when they were displayed.
Tim Dawson
Bronco II
Jan 1, 2007 10:29 PM
msgntsu
17
Jan 23, 2006 02:16 AM
kriswears
Aug 7, 2004 09:53 AM
BassGuy
1983 - 2012 Ranger & B-Series
Feb 1, 2004 08:29 PM
Ray D
Sep 5, 2000 10:14 AM
