Cam info please
Old Jan 3, 2024 | 02:34 PM
Mhurtado's Avatar
Mhurtado
5th Gear
Cam info please
Hello I have a 1992 f150, I’m looking into caming it with a e303plus cam, and I’m looking to get used gt40p heads to go with it. Anyone know if I’d need to replace the rods and lifters?
And if so, any recommendations?
Old Jan 3, 2024 | 04:27 PM
Mudsport96's Avatar
Mudsport96
Well, does it have a 5.0 or 5.8? The 5.0 will be roller so you COULD reuse the lifters. And MAY be able to reuse the pushrods.
That said, the computer won't run it without tuning. It will not drive well at all with the durations listed in the specs. And in reality, without a custom tune, you will be into the rev limiter before the cam stops making power.
Old Jan 3, 2024 | 04:43 PM
Mhurtado's Avatar
Mhurtado
5th Gear
I have a 5.0… thanks, I was somewhat clueless on the pushrods and lifters. Is it one of things I can get away with it, just kinda pushing the limits of the parts? Also the computer stuff I have to look into. But I apreciate the info on it, cuz I’d rather know than trying to do all this just to be stumped by a rev limiter
Old Jan 3, 2024 | 04:56 PM
rla2005's Avatar
rla2005
What is the scope of this project? Assuming you are looking for more power? Any other modifications already done?
Old Jan 3, 2024 | 05:18 PM
Hit Man X's Avatar
Hit Man X
P heads not worth the hassle and will need work as they are about 25 years old. E cam is dated tech with old school lobes. Skip both.
Old Jan 3, 2024 | 05:31 PM
Mudsport96's Avatar
Mudsport96
I think he is looking at the "new" E303 "Plus" that Summit racing is putting out now. It does make decent power, but it is a light car cam not a truck cam.
Old Jan 3, 2024 | 05:54 PM
Hit Man X's Avatar
Hit Man X
Ahhh. I ran the OG FMS one in a roller 306 in my old Towncar, good torque as it has good lift and 110LSA...but very lame idle vac as to be expected. No idea what that tipped the scales at, probably around 4500lbs.
'92 will be a roller block from factory, so yes the lifters, pushrods, distributor gear, etc will need to be swapped for a roller cam swap. I would put the cash in the heads and find some mild roller cam, make good power for cheap. Old Edelbrocks, old FMS GT40X/Y, Systemax, etc and rock a cheapo HO cam. Good budget combo, bet would do an easy 225-250rwhp depending upon exhaust, rockers, timing, etc. I saw an old dyno long ago of a whopping 135rwhp on one of these in stock form. Pathetic.
I have always heard a 2.02" intake will not clear stock pistons, unless TFS style heads...anyone know for sure?
Old Jan 3, 2024 | 06:09 PM
Mhurtado's Avatar
Mhurtado
5th Gear
currently I swapped out my intake to the van one that lets the air come in through the grill, with a m&ms air filter.and a msd box I’m aiming for more power baby. Lol. But I’m trying to build a street truck (eventually I wanna slam it, but that’s gonna be last cuz I wanna do truck things still). And I am looking at the new e303 plus cam, because I’m not gonna be hauling things in this truck
Old Jan 3, 2024 | 06:19 PM
Mhurtado's Avatar
Mhurtado
5th Gear
the original engine was swapped out with a 93 block, atleast according to the last owner
Old Jan 3, 2024 | 06:24 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I’m curious about the van intake. You mounted the airbox on the radiator core support? Most of us replace the 302/351 small intake tube section that draws air from between the core support and hood for the 300/460 tube that draws air from the grill. You wasted money with your MSD “upgrade.” The stock ignition system is more than capable of providing enough spark.
Old Jan 3, 2024 | 06:27 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Before you dick with much, run a compression and leakdown to check the health of that 302. If clapped, just start with a 351W...they are still in junkyards to pluck. I see many in vans. If it comes back healthy, then I would start with basic mods.
Gear with traction device (maybe you have a Traclok and just need clutches). Full exhaust. Bump timing a hair. Fresh AOD or at least mild shift kit with large cooler, looser torque converter. HO fan or the HD cooling 302 fan. Then look into camshaft options. You are speed density, so you need idle vacuum to keep the ECU happy.
Old Jan 3, 2024 | 06:28 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
My Spark Disappeared. BTDT. Tossed the 6AL I had in the trash, spark would drop when hot.
Old Jan 3, 2024 | 06:34 PM
Mhurtado's Avatar
Mhurtado
5th Gear
yeah that’s what I meant, I took the tube from the 460. Lol I’m at work and couldn’t think of the name
Dr.BunnyFooFoo
2004 - 2008 F150
Sep 17, 2021 07:42 AM
79302ranger
Apr 4, 2009 12:08 PM
flareside_thunder
May 31, 2007 06:42 PM
Jrock909
15
Dec 29, 2006 01:21 PM
