Reman engines
Old Jan 3, 2024 | 09:47 AM
Gicknordon's Avatar
Gicknordon
Reman engines
Does anyone have experience with any of the companies that offer reman engines for 6.7s? My dads 2014 had a bad rod knock and locked up. Ford motors are backordered to who knows when. Jasper and ATK seem to be the two main ones I can find info on.
Old Jan 3, 2024 | 10:24 AM
speakerfritz's Avatar
speakerfritz
a reman engin is an engine like you have now, but “fixed” to run.
No reman supplier will offer you a full list of what the reman includes.
that’s why they only warranty for 1 to 2 years.
you should also do an oil sample of the old oil if you still have it to determine if fuel dilution could have been a factor…if yes..then you have to investigate leaking cp4 pumps or leaking injectors.
Old Jan 3, 2024 | 12:32 PM
AK4x4's Avatar
AK4x4
You might check here; 6.7 Powerstroke diesel engines - Asheville Engine, Inc.
Old Jan 3, 2024 | 02:03 PM
acdii's Avatar
acdii
Jasper has been around a LOONG time and does a pretty decent job with their rebuilds. I used to install them back in the 90's and never had a bad rebuild from them. Same with their transmissions.
Old Jan 4, 2024 | 01:38 PM
Jenksie13's Avatar
Jenksie13
IMO better to buy a Ford factory used engine then a reman.
Old Jan 6, 2024 | 04:13 PM
TJP249's Avatar
TJP249
https://www.ford-trucks.com/forums/1...g-6-7-psd.html
astock
Mar 1, 2011 02:12 PM
Buzzman
General Automotive Discussion
15
Jan 6, 2008 12:09 AM
viperrtblck
Feb 15, 2006 09:27 AM
timothy47129
Oct 16, 2005 01:37 PM
darkman
Oct 15, 2003 08:47 AM
