Glow plug issues
Old Jan 3, 2024 | 07:52 AM
kaleb p's Avatar
kaleb p
Trailering
Glow plug issues
Hello all
just bought a 1990 f250 with the 7.3L IDI non turbo this summer. Glow plugs didn’t work when I bought it, wouldn’t even come on. I replaced all 8 glow plugs, glow plug wires and relay with no change. After that I replaced the GP controller and it worked flawlessly, WTS light came on for about 10 seconds and fired right up, outside temp being 35-40. But ever since then they will only come on for about 2 seconds and it won’t start. Any tips would be appreciated, my knowledge and skill with electrical systems is not great.
thanks!
Old Jan 3, 2024 | 10:53 AM
Olds64's Avatar
Olds64
What brand glowplugs did you install?
Old Jan 3, 2024 | 10:59 AM
kaleb p's Avatar
kaleb p
Trailering
I put autolite plugs in. The parts store said auto lite makes them for ford.
Old Jan 3, 2024 | 12:06 PM
mf7lakes's Avatar
mf7lakes
Get 'em out -- go OEM motorcraft
Old Jan 3, 2024 | 12:43 PM
Olds64's Avatar
Olds64
^^^THIS^^^
The Autolites probably burned out the first time you turned them on.
Old Jan 3, 2024 | 12:46 PM
Charmalu's Avatar
Charmalu
Autolites are short lived, can swell on the tips and difficult to remove..
and or break off and fall into the prechamber, and some times on top of the piston,
then the head needs to be removed.
Probably 1000 threads about it.
Charlie
Old Jan 4, 2024 | 05:52 AM
tjc transport's Avatar
tjc transport
i ain't rite
motorcraft glow plugs only for our trucks. original part ZD-9, which has been replaced with zd-29 to combat cheap chinese counterfit plug being sold on evilbay.
rockauto has 10 ZD-9's left for $8.66 each and the zd29's for $10.12
https://www.rockauto.com/en/partsear...T&partnum=ZD-9
Old Jan 8, 2024 | 07:35 PM
kaleb p's Avatar
kaleb p
Trailering
Thanks all for the help! I got motor craft ZD-29s and now three of the autolite won’t come out. They are all loose past the threads but the tips are stuck in. Any tips on getting them out or just soak em with PB blaster?
Old Jan 9, 2024 | 07:13 AM
tjc transport
i ain't rite
i soak with pb and connect a cordless drill to glow plug. than SLOWLY spin drill both directions while gently pulling up on drill. then push back down while spinning and spray, repeating process until plug comes out.
PATIENCE IS THE KEY HERE. take your time. if you get mad stop and take a break.
Old Jan 9, 2024 | 08:08 AM
kaleb p's Avatar
kaleb p
Trailering
Got the old autolites out (after several hours) and new motorcraft plugs in and it works like a charm. Thanks again y’all for all the help!!
Old Jan 9, 2024 | 11:26 AM
kevlook's Avatar
kevlook
Since I also recently acquired an old IDI, with no miles one it, should I get some of these for the future? Just in case they are unobtainium when mine wear out?
Old Jan 9, 2024 | 12:02 PM
tjc transport
i ain't rite
it would not hurt if you plan on keeping it until the nukes fly.
the last set i put in my 88 are 15 years old and still perk fine.
MantzD
Oct 4, 2022 07:05 AM
LFDavidson
13
May 9, 2022 04:26 AM
sonder
Sep 25, 2021 08:07 PM
Romel77
Oct 30, 2018 08:56 AM
Kfanson
Apr 27, 2012 07:29 PM
