Alabama Chapter Join Chapter , Leader: OPEN
Alabama chapter 2024 chat
Old Jan 11, 2024 | 01:09 PM
  #46
Steve GG's Avatar
Steve GG
I will gonin the greenhouse and get warm every so often.. maybe even stroll through store for a few minutes..
Old Jan 11, 2024 | 01:15 PM
  #47
56panelford's Avatar
56panelford
I hate it when you get a chill and have a hard time feeling warm...lol
Old Jan 11, 2024 | 01:18 PM
  #48
Steve GG's Avatar
Steve GG
I have my carhartts at work so they help fend off the cold.. I wore them the other night and was warm.. I just don't get along well with the extra weight I have to carry around when I am wearing them..
Old Jan 11, 2024 | 01:47 PM
  #49
56panelford
I've never had the need for insulated coveralls, underground I wore long underwear under regular coveralls, used to get quite warm on the lower levels but not warm enough on the top levels..lol
Old Jan 11, 2024 | 02:10 PM
  #50
Steve GG's Avatar
Steve GG
I like the insulated coveralls better than long johns.. If I have to work inside I can remove them and not get over heated..
Old Jan 11, 2024 | 02:21 PM
  #51
56panelford
If I worked outside I'd have a use for them..
Old Jan 11, 2024 | 02:22 PM
  #52
Steve GG's Avatar
Steve GG
I like the fresh air of being outdoors when working..
Old Jan 11, 2024 | 02:28 PM
  #53
56panelford
Better than smelling all the diesel fumes where I worked..
Old Jan 11, 2024 | 02:31 PM
  #54
Steve GG's Avatar
Steve GG
That is for sure.. Speaking of which.. I need to get some kerosene and Propane
Old Jan 11, 2024 | 02:34 PM
  #55
56panelford
I got to go see if I can fish this cord through the grill without getting frost bite..
Old Jan 11, 2024 | 02:45 PM
  #56
Steve GG's Avatar
Steve GG
Be careful and don't freeze..
Old Jan 11, 2024 | 02:49 PM
  #57
56panelford
I decided to make the cord inside where it's warm now that I know how long it has to be..
Old Jan 11, 2024 | 04:30 PM
  #58
winger4647's Avatar
winger4647
Was hoping to get the Bronco started on these 2 warm days AND OF COURSE it has to be difficult. Is a no-go. If I can get a hand tomorrow I'll see if I have spark other than that have no idea what is going on.
After I posted this first time I looked on the net for possible causes of my no-start. Evidently this is a common issue and USUALLY points to timing. Thought I would throw this at you all and see if you had any comments.
I do not believe the dist is 180 out as I first I marked the distributor location before removing and did not turn the engine over while doing the gasket change. When I first attempted a start I did get backfiring (using ether and then gas) through the carb. so I checked the TDC. TIming was close to 30 degrees advanced so I must have been a tooth off when I stabbed the distributor. I now have the TDC set at O and it will run at that setting just not good.
I am getting fuel I checked the sights on the the bowls. There is some dampness in the carb. I did turn the engine over using a breaker bar WITHOUT removing the spark plugs but it was a bitch. I did not check compression but I believe that is not the issue.
The engine though sounds strange (not normal) when it turns over. When assembled all was done by the book, have a hard time believing that would be an issue. Any comments?
Last edited by winger4647; Jan 11, 2024 at 05:22 PM. Reason: Research after posting
Old Jan 11, 2024 | 05:10 PM
  #59
56panelford
Turning over and no go Dennis, I once had the distributor out by 180 degrees..
Old Jan 11, 2024 | 07:58 PM
  #60
winger4647's Avatar
winger4647
I do appreciate that accept I did not turn the engine over after pulling the distributor. I dropped it in the same marked space (but it did not slide into the exact same place) so that would explain why out 30 degrees.
