E40d slipping gears?
Old Jan 4, 2024 | 08:52 PM
Nick05's Avatar
Nick05
Originally Posted by Mark Kovalsky
That is not limp mode. That is a failure. It could be low fluid, a loose or missing internal filter, or a worn out transmission.
Are there any codes stored in the PCM?
my scan port dosen't work is there a way to manually pull codes heard somthing about counting check engine light flashing not really sure
Old Jan 4, 2024 | 09:19 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The port is the way to pull codes. On earlier models you could count the check engine light flashes, but that won't work on your truck.
Old Jan 4, 2024 | 11:30 PM
Nick05's Avatar
Nick05
gotcha thank you
Old Jan 7, 2024 | 12:46 PM
Nick05's Avatar
Nick05
Idk if youll still see this but i went ahead and removed my psom to visually see if anything looks wrong and i dont think so. Can you tell by looking at it? Also wires look fine to me to the plug and harness. Another thing I belive my Rabs module is going bad and read somewhere that it could mess with the signal from the vss could that help maybe? I'm gonna unplug it to see
Ford_Guy_289
Aug 7, 2020 07:20 PM
airsoft1779
Jan 25, 2014 03:02 PM
7DF250
Sep 17, 2012 08:47 PM
sethticlees
Escape & Escape Hybrid
Oct 1, 2010 03:50 AM
