What is this?
Old Dec 30, 2023 | 06:37 PM
Rainmaker1's Avatar
Rainmaker1
What is this?
I know it’s a pump but does anyone know its purpose?
Anytime the ignition is on, it’s running seemingly full time. From the first moment the key goes to the ON position, it’s working away. What’s it pressurizing or pulling a vacuum for?
Old Dec 30, 2023 | 06:43 PM
WE3ZS's Avatar
WE3ZS
Wouldn’t that be your vacuum pump, the oil burners need the pump because they don’t generate vacuum like a gasser does.
Old Dec 30, 2023 | 07:11 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Correct
Old Dec 30, 2023 | 07:16 PM
Rainmaker1's Avatar
Rainmaker1
So it should be working full time?
I don’t recall if the previous Excursion was so auditable, this Ex is my third. Once driving I don’t notice it. How loud should it be?
Old Dec 30, 2023 | 07:56 PM
Antonm23's Avatar
Antonm23
No it should not be running full time. It should run, pull a vacuum in the vacuum reservoir ( black plastic thing mounted on the passenger fender well under the hood) then stop.
If it’s running full time you have a vacuum leak somewhere. If your truck is a 4x4, then most likely your auto locking hubs won’t engage. If the vacuum leak is bad enough, you’ll be stuck on defrost and not be able to direct AC to the vents.
Old Dec 30, 2023 | 08:06 PM
Rainmaker1's Avatar
Rainmaker1
It’s a 2001, 2WD w/ 7.3
The engine runs great. I’ll monitor it over the next few days and see if it ever shuts off.
Maybe it’s a good idea to start replacing vacuum lines. Not being equipped to do my own work, I hope the fix is easy. I could tackle the pump if it needed replacing, a few vacuum lines, but beyond that it’s back to the shop.
Cha-Ching$$$$
Is there an inexpensive and easy way to check for leaks?
Old Dec 30, 2023 | 08:53 PM
OldMechanic57's Avatar
OldMechanic57
Cha-Ching$$$$
Block off the two lines and power the truck up. This will give you a starting point. If the pump quits running, then you’ve narrowed your leak down quite considerably. If not then your problem isn’t with either vacuum circuit, but right there under your nose in the engine compartment right there over the passenger side fender.
Old Dec 31, 2023 | 01:02 PM
oharal's Avatar
oharal
Is there something you've observed to be not working?
Old Dec 31, 2023 | 01:44 PM
Rainmaker1's Avatar
Rainmaker1
That is what I’m contemplating. I’m a believer in if it works, don’t fix it, however although it seems a bit loud to me, everything works. The only thing that comes to mind is first time starting in the morning, until she warms up a bit, maybe 60-90 seconds acceleration is lacking when I take off for the first time. This only happens when she’s stone cold. Brakes and power steering perform as expected. Once it gets past that first acceleration, she runs strong.
Could there be a relationship between the two characteristics?
Old Dec 31, 2023 | 01:50 PM
oharal's Avatar
oharal
Ive never monitored mine but I'm fairly sure it doesn't turn off no matter how long it sits key on engine off and everything works as intended. As far as I know these systems are intended to run non stop providing consistent vacuum just like a gas engine intake does.
One thing is for sure, the vacuum pump has absolutely DIDDLY to do with engine operations. Your truck might feel slow in the cold until it warms up due to the exhaust backpressure valve closing to artificially load the engine and warm it up faster. Or it could be any number of other things.
Old Dec 31, 2023 | 02:02 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Mine seems to always be loud on first start of the day, other than then, I don't notice it. I changed to manual hubs and blocked off those vacuum lines at the pump. Oh... and I replaced the pump just a few years ago, so its always been loud...
Old Dec 31, 2023 | 02:04 PM
Antonm23's Avatar
Antonm23
It’s supposed to turn off once the vacuum reservoir is at the correct vacuum, or at least they all do on my 05 Excursion, my 08 f350 and my 2010 F250 diesel trucks.
Old Dec 31, 2023 | 03:20 PM
oharal's Avatar
oharal
In the interest of at least attempting to provide the same level of info to the forum that I receive from it, I walked out to my 02 Excursion 7.3 and keyed it on. I stood there for about 90 seconds maybe and the pump did turn off. In this regard I stand corrected.
Old Jan 2, 2024 | 04:09 AM
John in OkieLand's Avatar
John in OkieLand
that is normal, I never push my trucks faster than about 20 mph for the first few minutes.
I live next to a major US highway, if it is really cold out, I go around the block the opposite way on 30 mph streets, until things are ready to "hit the road'
Bsfu211
Mar 17, 2022 07:04 PM
F2spiffy
20
Aug 3, 2021 05:23 AM
PhilPalmiero
2021+ F150
Apr 17, 2021 05:40 PM
Resendiz
Oct 4, 2016 06:52 AM
johnarahill
Nov 28, 2011 10:05 PM
