400m timing help!
Don't bother messing with the advance until you know what it is . check your mechanical all in at 2500, if it's not 30-36 turn your distributor until it is. then check your initial. then hook your vac advance up and see where it's at all in and at Idle. there is no other way to find the answers you're after. once you know this you can fix what needs fixed.
but. What if I do just as you described and the second I hook up the vacuum advance (or Rev it to 2500) it backfires, spits and stalls out, seemingly to the ATDC side. What needs replaced then?
*the whole truck* 😂
Once you have the mechanical advance set then you can get the vacuum advance working. it sounds like one of two things are going on with it, either it's pulling the plate in the wrong direction because of your smog set up, or it's pulling the plate and causing a short in the pickup coil or feed wire. either way it can be corrected.
Recurving your DuraSpark distributor: Duraspark_distributor_recurve_instructions_index
Recurving replacement springs : https://www.summitracing.com/parts/mrg-928g?rrec=true
As usual I agree with what the others have already advised. But I have some questions and comments of my own to add.
I like learning new things!
And it's been asked, but I didn't see where you mentioned removing the EGR valve.
Nice introduction into old trucks and gas engines! Right?
And I might as well add here, because I didn't notice anyone else having mentioned it yet, there is no such thing as a 400M.
Since you're new to these, you've probably missed most of the discussions over the years, so I'll give it a quick (hopefully) go.
Only the 351's got the letter suffix, due to there being at least three of them running around at the same time. This was the W (for Windsor), the C (for Cleveland) and the M (for?) I always called it for "Midland" but most people nowadays settled on "Modified" though I don't know what that actually stands for, since it's the 351M that is a modified (de-stroked) 400.
Anyway, just sayin' you don't need the suffix for the 400. Only the 351.
Good luck on the doggy behavior. Not sure what's going on, unless it started running super lean due to some part of the swap, OR there is something wrong with your distributor that was not wrong before the swap.
A vacuum advance is just that. An ADVANCE! Not supposed to be able to retard timing, except for those few that were boost-retard setups for turbo engines. Never seen one of ours act out backwards.
Hope yours gets sorted soon, and turns out to be an easy fix.
Paul
Not sure, but it usually doesn't take too long. Hopefully we can see some images soon and maybe someone can point out something.
Paul
Anyhow, I stumbled across this thread because I'm having a strangely similar problem with an eerily similar setup. Someone mentioned needing to recurve the distributor because of the carb swap. I can throw my support behind that idea because mine has a Carter AFB on top of an Edelbrock Performer 400 intake. Not identical to the AVS of the OP, but close enough to make it seem like these engines don't like that carb. I haven't hooked up my timing light yet, plan to do so tomorrow. Since my setup is so similar, maybe I can find a tweak that will help. And I live five miles from Summit Racing here... just in case I need the advance curve kit, or an MSD distributor.
it’s good to know. And anyway, like I still say fairly often, it’s always good to learn something new on an old subject!
If you want to try some simple tests you can peak it out, which is always the best anyway. just keep advancing your timing a little at a time until you hear pinging ( detonation.) at WOT under load. then back it off a little until it goes away. this is your true maximum advance. now check and see where your settings are with a dial back. if it's all good you hit a home run. if it's not the work begins.
