Engine coolant temp, engine oil temp exceeds value?
Old Dec 28, 2023 | 02:58 PM
Spooledsrt's Avatar
Spooledsrt
Has anyone got this fordpass alert before? 2019 with 73k. Dealer changed oil, I drove home and parked it. The next afternoon I remote started it, when I went out a minute later the CEL light was on and I saw this on my Fordpass.
Old Dec 28, 2023 | 03:13 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Sounds to me like there is a bad sensor on one or the other.
Old Dec 28, 2023 | 03:21 PM
Spooledsrt's Avatar
Spooledsrt
both Temps have been reading the usual numbers during my drives. I dont know?
I can't find my obd2 reader to clear the cel. Waiting for the new one to show up tomorrow.
Also, I thought the remote start won't work if the cel is on, but it does?
ssls6's Avatar
ssls6
I assumed you checked the oil after the dealer oil change.
Old Dec 28, 2023 | 03:23 PM
Spooledsrt's Avatar
Spooledsrt
Definitely
Old Dec 28, 2023 | 06:01 PM
Just Chilling's Avatar
Just Chilling
Did the dealer use a motorcraft filter? I have seen those quick change stations use a cheap filter that does not have enough flow. That will make high temps.
Old Dec 28, 2023 | 08:40 PM
Spooledsrt's Avatar
Spooledsrt
Yeah they did. The dealer I go to doesn't have a quicklane for diesel, you have to schedule. I was monitoring the coolant and oil temp on an hour drive and the temps were normal range that it always runs at. So, I don't know. Looking forward to clear the light tomorrow when the obd2 reader shows up. Hopefully it was just a glitch and it won't pop up again. 2.5hr drive tomorrow, we shall see
JimmyRoach
Jun 12, 2021 07:09 AM
JT250
Dec 27, 2018 10:14 PM
Bigtruc
20
Dec 26, 2013 10:24 AM
jayc3169
Jul 25, 2011 03:26 PM
dredmond
Feb 26, 2011 02:48 PM
