Engine oil temp too high?
Old Dec 26, 2018 | 02:12 PM
JT250's Avatar
JT250
Heading up the mountain full of luggage and adults. Not pulling anything. Torque sent an alarm that said "Engine oil temp too high". It was 221*. I pulled over and was not spewing coolant. I could hold my hand on the coolant reservoir. The fan was running at normal speed. I never heard it kick in like it does when it is working hard. Should I assume torque is wrong or could there be an issue? The tell did go down after we got over the pass.
Old Dec 26, 2018 | 02:39 PM
Walleye Hunter's Avatar
Walleye Hunter
I always thought that engine oil was OK up to 250 or so. Your engine coolant cools your oil so it should certainly be higher than the thermostat you have in it.
Old Dec 26, 2018 | 03:15 PM
JT250's Avatar
JT250
I do not know the threshold of the oil temp. I have never monitored it. That is why I wanted to check. I used to have the 203* thermostat, but do t remember what I put in when I go the International water pump.
Old Dec 26, 2018 | 03:20 PM
andym's Avatar
andym
Yet another reason to carry an infrared temp gun. $20 on Amazon.
Amazon Amazon
Everyone should have one.
Old Dec 26, 2018 | 05:06 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I see 210-225 on a regular basis and have for years. I wouldn't worry too much about it.
Old Dec 26, 2018 | 05:11 PM
mike71800b's Avatar
mike71800b
The oil jets spray the underside of the pistons to move heat from the pistons to the oil and out through the oil cooler.
I keep my oil alarm at 240f and regularly see 230f pulling a light trailer in the summer.
https://www.riffraffdiesel.com/welded-piston-oil-jets/
Old Dec 27, 2018 | 09:34 AM
'88 E-350's Avatar
'88 E-350
221 isn't a big deal. Oil temp will rise more than coolant temp as the engine starts working harder, pretty normal. And while it won't take much to hit 220, it'll take a fair bit more to hit 230, a lot more to hit 240, etc. The oil cooler is way smaller than the radiator so it's easier to make the oil temp rise, but as long as it's working right it'll be difficult to actually get the oil too hot.
Old Dec 27, 2018 | 09:45 AM
beef tits's Avatar
beef tits
There is probably a parameter in your software to adjust the alarm setpoint. I'd put it to like 250.
Old Dec 27, 2018 | 10:04 AM
Wes444's Avatar
Wes444
https://www.amazon.com/Etekcity-Lase...ture+gun&psc=1
I actually have that one. Stays in the drivers door pocket, i grab it first thing when we stop while towing and check trailer bearings, then truck's (more or less), then tires
Old Dec 27, 2018 | 11:59 AM
JT250's Avatar
JT250
Thanks for all the responses. I will adjust the warning level. I didn't think it was a problem but wanted to be sure.
Old Dec 27, 2018 | 12:11 PM
beef tits's Avatar
beef tits
I'm curious whether 250 is even too high... what temp is oil good to?
My truck just runs quieter and smoother the hotter the oil gets, nature of the beast.
Old Dec 27, 2018 | 02:00 PM
Hussler's Avatar
Hussler
I believe the stock International water pump thermostat is 205*. With the after market 203* thermostat it starts to open at 190* and should be fully open at 203*. On my 97 I think it had the factory 190* and upgraded to the 203* when I replaced the water pump. That made a Hugh difference in performance when warm but the oil temps did go up also, but never saw more than 215* in summer hot months with no towing. And the fan was roaring big time.
Old Dec 27, 2018 | 10:14 PM
HD Rider's Avatar
HD Rider
The big rigs I drive regularly see 240 even in winter weather. I would set the alarm at 250F.
Towzilla
May 26, 2014 07:25 AM
Bigtruc
20
Dec 26, 2013 10:24 AM
Kyle799
Sep 14, 2013 04:51 PM
Traildust
May 23, 2013 05:39 PM
dredmond
Feb 26, 2011 02:48 PM
