EOT vs Coolant temp
Old Jun 11, 2021 | 08:35 AM
JimmyRoach's Avatar
JimmyRoach
EOT vs Coolant temp
2004 6.0 F350 using torque pro, my engine oil temp and coolant temp are less than a degree apart. I did not see any water in the oil when I changed oil this week. throughout comment I see that the temperature is more then 2 or 3 degrees. I read somewhere in a forum that as long as the engine oil temp and coolant temp are not exactly the same, your system is OK.
what is facts about the temperature difference and what should be indication of problems.
Thanks
Old Jun 11, 2021 | 09:18 AM
Motohead911's Avatar
Motohead911
You are fine. There is a Ford TSB on testing the oil cooler, also the tech folder has a procedure.
In a nut shell, drive you truck unloaded for 20 minutes on flat ground at 60 mph, if your oil is within 15°F you are good.
Also, you should do what is referred to as a cold soak for the temp setemps. Let the truck sit for 12 + hours and verify thar the oil and coolant temp are within 2°F.
Old Jun 12, 2021 | 07:09 AM
IHateCommieCars's Avatar
IHateCommieCars
Just to be clear, Moto means that you confirm the sensors are within 2d before you start it, and they should be approximately the ambient temperature at that time. Making sure your sensors are working correctly.
hi-jacker
Oct 11, 2019 11:01 AM
Bigtruc
20
Dec 26, 2013 10:24 AM
Kyle799
Sep 14, 2013 04:51 PM
jayc3169
Jul 25, 2011 03:26 PM
embry1123
Mar 15, 2011 05:14 PM
