Leaking fuel
Old Dec 26, 2023 | 06:43 PM
tamcphail's Avatar
tamcphail
Leaking fuel
94 F150 with single rear fuel tank. Anyone have any experience with it leaking at the connection of the tank and what I'm assuming is the filler neck? Can't get a great look at the leak origin but it's coming down to the frame right where I would imagine it connects to the tank.
Old Dec 27, 2023 | 09:34 AM
manicmechanic007's Avatar
manicmechanic007
It probably needs a new filler hose
They crack and start leaking
Pretty hard to see up in there, use a good flashlight and a flex mirror
Old Dec 27, 2023 | 09:41 AM
tamcphail's Avatar
tamcphail
Thanks! Hopefully that'll suffice
Old Dec 27, 2023 | 10:00 AM
My4Fordtrucks's Avatar
My4Fordtrucks
You’re going to order a part based on what it could be instead of actually verifying where it is leaking? I’ll throw in my 2¢. I’ve had the metal gas tank leak at the seam between the upper and lower half. It could also be the seal at the fuel pump.
93tankus
Oct 22, 2006 01:09 PM
dgeesaman
Mar 6, 2006 04:01 PM
yankeenica
1978 - 1996 Big Bronco
Mar 16, 2004 03:27 PM
jpavlice
Aerostar
Aug 30, 2003 05:09 PM
