Aerostar Ford Aerostar
Fuel Tank leak
Old Aug 30, 2003 | 10:03 AM
jpavlice's Avatar
jpavlice
Fuel Tank leak
It appears that I have fuel leaking from the top of the fuel tank on my 90 XLT (3.0L, 2WD). Any ideas as to the most likely culprit? How hard is it to remove the tank?
Old Aug 30, 2003 | 05:09 PM
JTHill24's Avatar
JTHill24
Fuel Tank leak
If it's like my 89 just 2 metal straps holds, plus you have to take loose a hose clamp on the filler. Most likely you have a bad plastic fuel line connecter. But you have to get to the top of the tank to replace it.
Oh! And make sure the tanks almost empty. It's a lot heavier with gas in it.
