There is a fuel leak that keeps the frame wet where the spare tire hanger bolts into the frame on the drivers/forward side. I can see a few fuel lines up there but none of them is visibly leaking. I only get it when the rear tank is full. There are no fuel crossover problems *knock on wood*. From below, both tanks appear to be intact and without leaks.
So I can assume it's the rear tank since the leak is closest to the front/left corner of the aft tank?
While we're on it, I see 38gal tanks available for the 80-89s. Does anyone know about an aftermarket or swap that allows a larger capacity rear tank in a 95?
