Trans temp sensor
Old Dec 27, 2023 | 10:37 PM
fordman67's Avatar
fordman67
Originally Posted by Ashton_1012
Ok I have a little bit more helpful information… now that I have the CTS3 monitor I can see exactly what gear I’m in.
in second gear it doesn’t shift until about 24-2500rpms. It then shifts into 3rd, rpms drop to about 1900, and a second later it feels like it’s shifting again, but it’s still in 3rd and RPMs drop a bit further. I shift into 4th just fine.
I will admit I’m very transmission naive. I can make my way around the engine compartment fairly well, but when it comes to transmissions I’m dumb. This could be completely normal, I don’t know. Any ideas? It’s $180 to diagnose at my local transmission shop, or about $250 just to drop the plan myself and swap in a John Woods valve body that should correct the temperature sensor and perhaps this shifting issue. I am confident I can get that done. I’d hate to spend $180 extra just to find out I need to do the $250 fix. Or does this sound like a torque converter problem, and could the two be correlated?
Valve body and solenoid pack are different components. More testing is needed or its just all a wag. The trans will never shift correctly if it does not know temps.
Old Dec 28, 2023 | 01:07 AM
INFRNL's Avatar
INFRNL
the extra shift is most likely the torque converter locking up and is normal.
If you have a code and Mark said it needs to be diagnosed, that's what you should look into. Have you tried clearing codes and see if it comes back?
Also, I wouldn't run 2 coolers, not sure if there is a negative effect.
If you want a VB, then get one and see if anything changes. as Mark said it's rare for the sensor to fail
Old Dec 28, 2023 | 10:07 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I can diagnose this WAY cheaper than that.
The "shift" you feel in third gear is the torque converter locking. It is working as designed. Nothing to fix there.
cdiddy
Apr 28, 2009 07:44 PM
don77
Apr 20, 2009 09:16 PM
mchild
May 28, 2005 05:44 PM
nubwon
Oct 2, 2004 05:36 PM
