AOD -E4OD Swap (electronic issues)
Old Dec 23, 2023 | 07:49 AM
Pushachevy's Avatar
Pushachevy
Thinking about doing this until someone talks me out of it ... I have a 1991 F150 302 with AOD and would like to put the E4OD out of a 1990 F150 with the 300 cu in six..... I have both trucks here.... and might eventually put the 300 engine into this 1991 also .... the 1991 is a very clean Florida truck. And if too much trouble then probably going to put in a 5 speed since I have one of those also.... The AOD is dis assembled with pieces in boxes..... I have a great E4OD.... so what should I do ?
Old Dec 23, 2023 | 08:27 AM
1Butcher's Avatar
1Butcher
The early E4OD's were not Ford's best product. If you elect to go with the E4OD, I would go through it. If you are not good with electronics, maybe pass.
Old Dec 23, 2023 | 09:20 AM
rla2005's Avatar
rla2005
With a complete parts truck you have an advantage over someone who needs to scrounge for parts. As stated if you are not good at wiring, it will still be an uphill battle. Best advice is get an EVTM manual for each model year then start tracking any wiring differences, should be close, but there may be a few gotchas. Keep as much of the original harnesses intact is the best way to go. Adapt the transmission specific wiring to your 1991.
Agreed you should also give that donor E4OD a good thorough inspection instead of tossing it in.
Old Dec 23, 2023 | 10:31 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
And you'll need a PCM for a 302 with E4OD. The PCM in your truck won't control the transmission, and the PCM from the other truck will only run a six cylinder.
Old Dec 24, 2023 | 08:42 AM
Mudsport96's Avatar
Mudsport96
Manual swap will be the least wiring intensive.
Old Dec 24, 2023 | 01:20 PM
Hit Man X's Avatar
Hit Man X
Find another AOD. Build it yourself. Reinstall it... quickest and easiest to do.
Old Dec 24, 2023 | 01:35 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The E4OD sucks up a lot of power. I’d stick with a rebuilt/ upgraded AOD.
EgoMan
Jun 24, 2006 01:33 AM
turboguy
Mar 13, 2005 04:36 PM
SAX
1978 - 1996 Big Bronco
May 13, 2003 07:41 PM
wannab4wd
Nov 21, 2001 06:42 PM
