6.2L V8 Discuss the 6.2L V8
Which coolant?
Old Dec 23, 2023 | 04:53 AM
Qwazert's Avatar
Qwazert
Which coolant?
So I want to do a coolant flush this Spring. 2012 F250 with the 6.2 gas engine.
Are we still using the orange MotorCraft coolant or has this change?
Is there a universal coolant that I can get WITHOUT going to the dealer?
Old Dec 24, 2023 | 11:22 PM
Lamoon78's Avatar
Lamoon78
Any coolant works. I run Amsoil in everything I own so I just use their coolant never a issue.
Old Dec 25, 2023 | 04:30 PM
railroader's Avatar
railroader
Peak is fine for my truck. It's not the antifreeze that is the problem, but the stuff that ends up in the coolant system that shouldn't be there.
Old Dec 25, 2023 | 05:08 PM
Split rims's Avatar
Split rims
Motorcraft YELLOW!
Old Dec 28, 2023 | 12:10 PM
explorerdriver's Avatar
explorerdriver
I used that Ford Flush Product (VC1), a few clean water flushes, and then Motocraft yellow w/distilled water. Orange was there before. I heard Motorcraft Yellow is Prestone.
That is exactly what the dealer here does for a premium coolant service.
Old Dec 28, 2023 | 12:26 PM
railroader's Avatar
railroader
To tell you the truth, I can't remember when I have ever flushed a coolant system, except when back in the day(70's), I either relied on Bar's Stop leak, to get back to the house, or when I rebuilt an engine.
I just look at it, and if it looks like what I put in, I'm good. If a thermostat goes bad, or a water pump gets changed, it just gets topped off with what I put in the last time. And the stuff I use is Peak or Prestone, whichever is cheaper, and never any of that 50% mix crap.
Ford's antifreeze is just someone else's with a different label.
I had the water pump changed on the 2011 F250 at 100,000 miles, because it started whining. Pretty good, I think.
Old Dec 28, 2023 | 01:19 PM
explorerdriver
Dealer talked me into that flush product, I used it on all the cars. They swear by it. It is approved by Ford for service.
Also have an 11 6.2L. I put in a new Ford Tstat too, was $10 or so. I thought of a WP at 200K, but if it ain't broke, don't fix it!
Old Dec 28, 2023 | 01:26 PM
railroader's Avatar
railroader
That's awesome for a water pump.
6805eagleguy
6.7L Power Stroke Diesel
Mar 13, 2022 04:29 PM
fski50
Apr 26, 2015 08:28 PM
A/Ox4
Apr 3, 2013 07:14 PM
Milwaukee1979F150
Jul 6, 2012 08:27 AM
Saxon
Aug 6, 2004 11:15 PM
