Red coolant.
Old Mar 7, 2022 | 09:52 PM
6805eagleguy's Avatar
6805eagleguy
Red coolant.
Hey guys, i bought a 2016 f250 6.7 from texas, completely stock except for both coolant systems are filled with red coolant. Im pretty sure this is just red semi coolant and this truck came from a construction company. On all my existing 6.7s i religiously run ford coolant. Should i be worried about the red coolant? Flush and change out with ford orange? Or send it?
Old Mar 7, 2022 | 10:15 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
If it is red coolant it is most likely ELC of one brand or another. Nothing wrong with using ELC and you benefit of not needing to add anything along the way between change intervals.
Old Mar 8, 2022 | 05:22 AM
RetiredRich's Avatar
RetiredRich
Trailering
You are probably aware that using the wrong coolant can lead to corrosion issues. And, color of coolant isn't a perfect indicator of type.
If it was me, I'd take the truck to a dealer and have them test the coolant. They have what appears to be litmus paper to do this with. (I did this recently and it took 2 minutes and there was no charge either)..
Cheap peace of mind.
Rich
Old Mar 8, 2022 | 03:19 PM
Dirthawg2.0's Avatar
Dirthawg2.0
The Motorcraft Orange has been discontinued. The new coolant that replaces the Orange is Yellow and actually looks fluorescent green.
Old Mar 13, 2022 | 12:58 PM
F350 1990's Avatar
F350 1990
I run Red Caterpillar coolant in all my equipment ---- if it's good enough for $M dollar CAT equipment, it's good enough for my 6.7Ls
Have used for years --- works perfectly.
Old Mar 13, 2022 | 04:29 PM
mebe2k's Avatar
mebe2k
I've been running the red ELC in my 2011 6.7 for years..no issues...still have the original radiator in it also*knocks on wood* truck just hit 200K a couple weeks ago
dirthawg
6.7L Power Stroke Diesel
May 2, 2019 05:13 PM
bedwards
2015 - 2020 F150
Dec 9, 2018 06:03 PM
sand1
Feb 28, 2017 02:09 AM
Milwaukee1979F150
Jul 6, 2012 08:27 AM
Saxon
Aug 6, 2004 11:15 PM
