I want to buy a scan tool for my truck; 2006 F-250 6.0. I'm asking for your recommendation. I use Apple computers & phones, but have access to an IBM clone laptop.
It doesn't have to be cheap, I want a good one that will help me get this truck running again. I'm having high pressure oil issues, crank/no start.
Do you want the ability to command actuators and maybe do some PCM "re-programming"?
ForScan is the best bang for your buck. You can get it as a full version (free) for a Windows laptop or the Lite version for a smartphone.
The laptop can use an "OBDII to USB" adapter OR an "OBDII to BlueTooth" adapter if you have Bluetooth capability on the laptop.
The best adapter for a smart device IMO is the OBD MX+, but cheaper ones will work adequately if all you are going to do is read codes and read PCM PID data.
Thank you, I have a few bluetooth OBD II adapters I used in conjunction with TorquePro. The tablet I used is no longer functioning, so I thought I would upgrade. I will look at ForScan!
I recently had a need to to address an issue on my wife’s Cadillac with the StabiliTrack system. While many devices can show the codes, I needed to do a Service Procedure, specifically a steering angle calibration. I have also migrated away from Windows based computing and do all my stuff on iPad for the last several years. After a bunch of research I found a couple of devices that will do bi-directional OBDII (modes 8 thru 10 (or 0A)) and communicate with Apple products on Bluetooth. I Settled on one Called TopScan Pro by a company called TOPDON. It works well and is stable on iPad and iPhone. The company has many different devices for automotive work and this is a “home gamer” device in their line up, under a hundred bucks and comes with a software license for a year. Annual renewal is about the same price. It requires a vehicle specific download basically by manufacturer and a few by model. The company is very responsive and you can even contact them directly thru the app. I interacted with them in the comments section of a YouTube video and they got back with me giving solid answers on technical questions in just a few hours (before I bought the product). I haven’t had a need to connect it to my truck yet but I’ve used it on a few different vehicles now and have been impressed. I’m confident it will do whatever might be needed on a 6.0 powered vehicle.
I just read my post and realized I sound like a cheerleader but I’m not affiliated with the company, just happy to have found something that works well. I have some downtime this week and have considered making a video of this thing and I guess I could use my truck (2006) if anyone is interested in seeing how that goes.
FORScan is excellent for Ford and Mazda running on a Windows device. If you want to diag other makes of vehicles or don’t have Windows in a portable device there are other options that work well.
Lets see. FORScan for $60 to $180 (depending ONLY on the adapter you choose). Fancy scan tool (that really doesn't do more than the full version of FORScan) for $2500. Not a hard decision.
I use FORScan whenever possible for its ease of use (and I love the injector buzz test), but for more in depth diagnosis I use a Ford IDS/VCMII setup (which I got on the cheap). Both of these I have running on an old $50 laptop.
I got mine from dieselscanners and I've had it for years with no issues. I bought it 3 years ago and never had any problems with using it. Comes with every software I need and does everything that I would need it to do and more. My buddy got one too and loves it.
