Sponsored by: Real Truck
Scan tool
Old May 17, 2022 | 06:32 PM
therigwelder's Avatar
therigwelder
Scan tool
I have just purchased a 07 f450.I am looking for the lowest price scan tool that will read icp,ipr pressure and will help me diagnose non start conditions.wow I just looked at my membership and I've been a member for 21 years😀
Old May 18, 2022 | 08:03 AM
bwguardian's Avatar
bwguardian
Forscan free version will do that. I have it and also bought an OBII reader off Ebay for another $20. You can use your phone with wifi, it's not as reliable as the OBII though...
Old May 18, 2022 | 09:34 AM
therigwelder
I looked at the forscan and I am confused on the adapters.i read reviews saying not to buy the elm327 adapters off Amazon ,they are bogus counterfeits.i want the adapter to go to my laptop not the Bluetooth one.so what adapters is everyone using.?
Old May 18, 2022 | 09:39 AM
bwguardian's Avatar
bwguardian
I have been using the ELM 327 Interface v1.5 with MS-HS can switch for several years now with no issues...
Old May 19, 2022 | 08:51 AM
geodane's Avatar
geodane
I bought the OBDLink EX FORScan Adapter from Amazon and it has worked perfectly.
Old May 20, 2022 | 07:58 AM
JKru's Avatar
JKru
If you buy your ELM327 adapter from a reputable manufacturer/distributor, then you'll be fine. They're just cautioning you against the cheap knock-offs that are out there. The OBDLink adapters are good stuff.
Old May 20, 2022 | 01:30 PM
leadmic's Avatar
leadmic
^This^...!
Old May 21, 2022 | 10:31 AM
speedfreak78's Avatar
speedfreak78
OBDLink EX. It's a more expensive product, but it's been proven to be reliable. Also, it's specifically designed to work with Forscan. With the amount of diagnostics capability you get with Forscan and the ability to alter factory settings, it's a program that's easily worth hundreds of dollars. I thought it was worth it to spend a little more on a quality cable
Old May 21, 2022 | 05:24 PM
therigwelder
i bought the vLINKER FS USB from vgate.This one is recommended by FORscan
hello113
Sep 23, 2017 10:55 PM
husq_tech74
Jul 18, 2008 10:06 PM
