Mirrors Issue
Old Dec 19, 2023 | 12:20 PM
topsmith's Avatar
topsmith
2nd Gear
Mirrors Issue
I just purchased a 2019 F-350 Lariat diesel from a private party. Truck is in great shape.and has a lot of miles on it, but from the looks of the body, under carriage and engine compartment, I don’t believe it’s seen anything besides highway traffic.
i have an issue with the mirrors, specifically poor-or-no response to the down and left adjustment button for both left and right side. I just replaced the control switch, but the problem still remains.
Any remedy suggestions would be appreciated.
Old Dec 19, 2023 | 12:27 PM
scraprat's Avatar
scraprat
Top Answer: 5
Have a look at this video you may need to adjust the clips some where it pops in to the mechanism that adjusts.
Old Dec 19, 2023 | 01:07 PM
topsmith's Avatar
topsmith
2nd Gear
Mirrors Issue
https://youtu.be/MThSJjWhSmo?feature=shared
BOTH mirrors malfunction utilizing the ‘down’ and ‘left’ arrows. I believe that both mirrors are original, so I doubt it is an attachment clip issue. That’s why I jumped on a bad switch, which unless the new one is also faulty, is not the problem. Are there any other common components between the switch and the actual mirror that you’re aware of? And, do you know if this is a common problem with the mirrors?
Old Dec 19, 2023 | 01:37 PM
scraprat's Avatar
scraprat
Top Answer: 5
My 21 does it, both the driver and passenger. The down to a certain point and outward to a certain point. I just live with because once it's set, it's set. I haven't taken it apart just because I can live with it.
Old Dec 19, 2023 | 02:30 PM
jimzpsd's Avatar
jimzpsd
If you can hear the small electric motor running (in the mirror housing) while using the switch (either side) then that confirms the power and switch are good and this is a common fix on some trucks sooner or later, by cleaning and readjusting the three prongs that guide the mirror on the drive disc. Also if the mirror wants to move, sometimes helping it by hand will help. If there is no power and no sound, then time to search...fuse, loose wire, etc.
Old Dec 20, 2023 | 11:36 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Dealer just replaced both mirror motors for this exact thing 2020 450 68k miles
ZooDad
Old Dec 20, 2023 | 10:15 PM
Edd505's Avatar
Edd505
Originally Posted by ZooDad
Dealer just replaced both mirror motors for this exact thing 2020450 68k miles
ZooDad
You don't want to buy one, I had a tires shop damage telescoping tow mirror backing out of the bay, they said OEM replacement on the 2015 was $800+.
Another F250
Feb 12, 2023 07:21 AM
Gianni
Aug 17, 2017 02:00 PM
mck2000
2011 - 2019 Explorer
Jan 31, 2014 10:52 PM
vrysnky
1997 - 2003 F150
Apr 18, 2007 08:43 AM
ggbert
Mar 31, 2000 08:23 PM
