Sponsored by: Auxito
Reset power mirrors?
Old Apr 17, 2007 | 06:04 PM
vrysnky's Avatar
vrysnky
The other day at work, someone was "playing" with my truck when I was not around. The pushed the side mirrors, one all the way up and one all the way down. I tried to get them about where they were before, but now when I use the controls on the door, down is left, left is up, they will only go so far in one direction and none in the other, etc. Is there any way to get them back aligned or "reset" in place so they will work the way they are supposed to? Any help is appreciated. thanks.
Old Apr 18, 2007 | 08:43 AM
Racerguy's Avatar
Racerguy
There's nothing to reset on the mirrors.
It sounds like you need a new switch. I've replaced lots of them for the same problem.
If I had to guess I'd say that you probably hadn't adjusted the mirrors in quite a while so you didn't know that the switch didn't work right and then when your "friend" moved them you found out the hard way.
fivonut
Jan 25, 2018 03:08 PM
StanleyZ
6.7L Power Stroke Diesel
79
Apr 9, 2015 06:08 AM
Archimandrite
Dec 1, 2014 05:34 PM
spatengal
Sep 26, 2012 12:18 PM
1977f150xlt
13
Jul 18, 2009 04:29 AM
