Electrical problem, need help!
Old Dec 14, 2023 | 11:26 AM
holguinrl's Avatar
holguinrl
1st Gear
I have a 79 Ford f100 with a 302 Windsor. I just picked this truck up about 6 moths ago. I got it running, enough to move it. Parked it in my front yard.. I tried to start it and a lot of noise was coming from the starter. So I replaced it. Then come to notice, a good few wires were burnt. So I replaced them. But now when I go to start the truck., nothing happens, no clicking, nothing at all. Any help with troubleshooting would help!
Old Dec 14, 2023 | 12:12 PM
tbear853's Avatar
tbear853
Fusable Link burnt up after a short it sounds like. Need to find them and check, and determine why the short happened before replacing any blown links.
Old Dec 14, 2023 | 01:22 PM
uzikaduzi's Avatar
uzikaduzi
replacing ground straps while you're looking for whatever likely caused the wires to burn up would be good maintenance and could actually be the issue itself... i'd also proactively replace the starter solenoid. i think you'd be like $50 total for those and they could ultimately be part of the problem you have
Old Dec 14, 2023 | 02:27 PM
Viper Pilot's Avatar
Viper Pilot
Do you get any power to the gauge cluster, lights, etc when you turn the key to accessory or run? If not, I guarantee it's the fusible link. Either that or you forgot a ground connection somewhere as mentioned above.
Old Dec 15, 2023 | 10:28 AM
mark a.'s Avatar
mark a.
Where was it burned ? Which wires did you fix ?
Lt0
Aug 1, 2023 08:55 AM
nova racer
20
Nov 20, 2013 08:58 AM
WoodGrain
Sep 25, 2009 06:15 PM
FordNFishinLover
Aug 5, 2009 11:41 AM
DirtStripHero
16
Jun 9, 2008 05:58 PM
