Back window--- wipers
Old Dec 26, 2023 | 08:16 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
The manufacturer/vendor Kool Cars doesn't appear to be around anymore.
Old Dec 26, 2023 | 09:49 AM
Scotty's 52 F3's Avatar
Scotty's 52 F3
@headloct, This is all I found on a quick eBay search. https://www.ebay.com/itm/22542273462...Bk9SR5iW6OyUYw
Old Dec 26, 2023 | 09:55 AM
bmoran4's Avatar
bmoran4
That one looks like the same over seas manufacturing as the less costly Amazon offerings shown earlier in this thread.
Old Dec 27, 2023 | 09:28 AM
bassdr's Avatar
bassdr
Originally Posted by headloct
Dealing with a 1955,I think F100...Not mine. The owner attempted to install the rear glass,ruined the rubber but didn't break the glass. I got called in because I'm a so called expert but I can't get this thing in. The glass is original,cab undamaged,he got the rubber from LMC,don't know the brand. It appears the gasket is too big as I can pull either the top or the bottom easy enough but when going around, the rope gets extremely tight and it becomes a no go. The rope and rubber were lubed with dish soap. I guess the questions are what brand rubber is best and are there any tricks I need to know? The truck has been converted to 12v. It appears that the after market 12v wiper motor assembly is NLA at this time. The original 6v works good. I tried a couple 12-6v adapters but they are apparently for low amperage and didn't work at all. Does anyone know of a voltage reducer that will work? Will 12v be OK? Thanks!!
I had a similar thing happen when replacing back window 51 F1. Had new glass cut to match old one (cracked). then tried to install with new LMC gasket. no go, even after having glass sanded down twice. eventually forced too hard and broke glass and bought new glass from LMC. Moral is LMC glass and gasket do not play well with others.
Power_Stroking
Mar 10, 2021 08:48 AM
wipper
Aug 28, 2007 09:11 PM
BootHill
1978 - 1996 Big Bronco
Mar 15, 2005 10:31 AM
mickf66
Appearance & Dress-Up
Sep 19, 2004 12:28 AM
Supercab
Paint & Bodywork
Sep 18, 2002 09:36 PM
