General Automotive Discussion
Active Ingredients - Coolant Flush
Old Dec 8, 2023 | 04:13 PM
LongRider's Avatar
LongRider
Does anyone know what the active ingredient is in Blue Devil ?
Thanks.
Old Dec 10, 2023 | 12:35 PM
Johnny Paycheck's Avatar
Johnny Paycheck
https://gobdp.com/wp-content/uploads...4_RAD_MSDS.pdf
Sodium citrate, which is a citric acid salt. A smidge of EDTA Tetrasodium, which helps clean metal corrosion out of the cooling system.
Old Dec 10, 2023 | 05:11 PM
LongRider's Avatar
LongRider
Many Thanks !
The Prestone says right on the bottle "Sodium Citrate"; either it does not contain nearly as much, or the EDTA Tetrasodium makes all the difference.
You seem to know about this stuff; could I have mixed the Prestone with the Blue Devil in the same flush cycle ?
Reason I ask is the local store only had a single bottle of each and my system calls for at least two bottles.
I just did one flush with the Prestone, followed my many rinses of plain water, and then a flush with the Blue Devil.
It is amazing how much more crud the Blue Devil brought out compared to the Prestone; the Prestone being first, I would have thought it would have showed more regardless.
Old Dec 11, 2023 | 08:24 AM
JWA's Avatar
JWA
^^^You'd be well advised to contact the manufacturers of those products seeking their input on compatibility in actual real-world use. IMHO anyway.............
Gangly
Mar 31, 2017 08:00 AM
sudsmcduff
Mar 26, 2016 04:13 PM
Big-Red-Lariat
2004 - 2008 F150
Dec 26, 2010 12:33 PM
kupaa
Jan 26, 2008 09:52 AM
