antifreeze
Old Jan 26, 2008 | 09:37 AM
kupaa's Avatar
kupaa
antifreeze
is it all right to add the green ainifreeze from costco,its made by Peak and treat it with RMI-25 that i got from dieselsite.com.I will flush the system with radiator cleaner before i do this.Aloha Chris
Old Jan 26, 2008 | 09:52 AM
F350-6's Avatar
F350-6
There's nothing wrong with the green coolant. If that's what you want to use go ahead. Like you mentioned, flush, fill, & use the additive. Use the test strips and check it every so often and you'll be fine.
