Coolant Temperature
Old Dec 6, 2023 | 09:36 PM
speedemon1084's Avatar
speedemon1084
Coolant Temperature
I am new to Powerstrokes. Is this normal operating temperature? Seems kinda low to me. I have had the truck about a week. 2000 f250 7.3
Old Dec 6, 2023 | 11:53 PM
udsuth78's Avatar
udsuth78
That is a preprogrammed gauge position from the factory. It will always read that way anywhere between normal operating temp and just before "Oh God I think I melted a piston!" That gauge is not to be trusted for anything period. Most of us run either a dedicated gauge for oil temp or use one system or another that piggybacks engine PID's and monitor oil temp among others electronically. Why oil temp you might ask. Because it's a more accurate gauge of overall engine temps and It's a PID we can actually view through scan devices. A lot of the earlier models the PCM didn't have access to coolant temp readings only oil, and if the PCM can't see it then we can't see it without a dedicated aftermarket gauge.
Old Dec 7, 2023 | 03:35 AM
John in OkieLand's Avatar
John in OkieLand
I use a Edge CTS-3 monitor, and I have EOT on the main Display.
I am not concerned about the actual Coolant Temperature, it will be within 10 to 15 degrees of the oil temp.
Note IAT: it was raining most of the day, and I got tired of following Semi trucks. the boost is low, as I was backing off the throttle.
this shows the Clearest screen Image I have, it was snapped just as I was passing a Semi.
Old Dec 7, 2023 | 03:40 AM
John in OkieLand
before you ask, the phone was in a Windshield mount set on a timer.
Old Dec 7, 2023 | 07:40 PM
INFRNL's Avatar
INFRNL
I wouldn't even use the gauges on the cluster, they are a joke...but yes it's normal. Mine always reads low too.
Old Dec 7, 2023 | 11:12 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
OEM dash coolant temp is not bad really. I believe it does go in steps, not a linear representation, but close enough. Yours looks normal.
It's the trans temp gauge that really sucks. Will not show hot until too late. Best to have either a dedicated gauge or a reading from the PCM, which is quite accurate.
Frostyllama
Sep 11, 2021 03:26 PM
Sooper Camper
Nov 30, 2013 09:24 PM
ambrose2004
Dec 26, 2011 09:42 AM
John - NNY
Nov 16, 2007 04:36 PM
Customz
May 8, 2006 11:24 PM
