Sponsored by: Auxito
1998 F150 Issue.
Old Dec 6, 2023 | 09:53 AM
ccagle95's Avatar
ccagle95
7th Gear
1998 F150 Issue.
Good morning,
I am having some issues with my 1998 4.2 automatic truck. Just installed a reman trans, radiator, and trans cooler maybe 5k ago. Well, trucks been doing great 145K miles. Well, over the weekend it started having a miss fire under load. Then everyday got worse but seems to clear up once truck is warmed up. Doesn't throw any codes. Changed the plugs. Didn't help so I ordered coil pack and wires. Supposed to be here tomorrow. On my way to work this morning it missed then acted like it didn't want to shift into 3rd and then shifted hard. It did that a few times and then the OD switch light flashed twice and went off. I know that means trans issue but could a possible bad coil pack and harsh misfire cause the trans to maybe "freak out" and flash the OD light? before this morning it hasn't done anything like that but it missed a lot harder this morning.
Old Dec 6, 2023 | 11:34 AM
BareBonesXL's Avatar
BareBonesXL
What happened to the old transmission that required a replacement?
You've probably seen this. If not, it might be worth viewing.
Old Dec 6, 2023 | 12:14 PM
ccagle95's Avatar
ccagle95
7th Gear
Lost Overdrive then ended up Losing all forwards gears.
Old Dec 6, 2023 | 12:48 PM
ccagle95's Avatar
ccagle95
7th Gear
Lost over drive then all forward gears In it.
Old Dec 6, 2023 | 10:31 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'd say fix the ignition issue and see if the transmission issue clears up.
Old Dec 7, 2023 | 06:35 AM
projectSHO89's Avatar
projectSHO89
"Ignition issues" are not going to cause the transmission to lose all forward gears.
Old Dec 7, 2023 | 09:26 AM
ccagle95's Avatar
ccagle95
7th Gear
That has nothing to do with what I am asking.... that was why I changed the transmission in the past.
Old Dec 7, 2023 | 09:55 AM
projectSHO89
So, what is your actual question?
Old Dec 7, 2023 | 12:38 PM
BareBonesXL
Good morning,
I see some engine missing, and some shifting issues, and a flashing OD light.
I don't have an answer for the question about a poor running engine causing transmission problems. But, I wonder if an electrical problem could cause all of the problems. Bad grounds, wet GEM, etc.
You should have the new coil pack in hand. Install it, check all of your wires and connections, and see if the engine problem is gone. Then focus on the transmission problem. Hope you bought Motorcraft, it's worth the extra considering how long a coil pack lasts.
Another thing to consider is that a typical "stuttering" transmission problem might feel like an engine miss. Are you positive that the engine is misfiring? Good luck.
Old Dec 8, 2023 | 02:19 PM
ccagle95's Avatar
ccagle95
7th Gear
Update, problem is fixed found a plug wire melted that ran on the back side of the motor on the passenger side. Changed the plug wires and fixed the issue.
ccagle95
3.8 & 4.2L V6
Dec 6, 2023 09:42 AM
sccamper
Apr 6, 2013 08:02 PM
ZRNation
1997 - 2003 F150
Jan 15, 2013 11:58 AM
hartski
2004 - 2008 F150
May 31, 2012 01:46 PM
n5926g
2004 - 2008 F150
Jun 27, 2011 01:17 PM
