spring bushings
Old Dec 5, 2023 | 05:26 PM
meborder's Avatar
meborder
spring bushings
On a single axle leaf spring trailer, how many bushings are there per side?
2 or 3?
i found a kit on amazon that is priced right, but it looks to me that it would be short 2 bushings. it comes with 4, but isnt there one at the top of the rear shackle where it attaches to the frame?
or am i wrong?
Amazon Amazon
Thanks in advance!
Old Dec 5, 2023 | 10:20 PM
OBS460's Avatar
OBS460
Single axle leaf spring setup should just have 2 spring bushings per side. One for the front eye and one for the rear.
Old Dec 6, 2023 | 08:17 AM
AZSCAWPION's Avatar
AZSCAWPION
It seems to me that the kit you linked to is a shackle kit which includes only the shackles and corresponding bushings. Yes there are typically (2) bushings at both spring eyes (unless slipper style) and a 3rd at the shackle to frame mount.
Old Dec 6, 2023 | 01:02 PM
meborder's Avatar
meborder
That’s what I’m trying to figure out. I had it in my head that there should be a bushing at the top of the shackle.
I guess it isn’t that expensive to just get a couple more bushings. But to me there should be 6 bolts and 6 bushings. But I’ve not had one apart that far yet.
Old Dec 6, 2023 | 10:50 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
The video shows bushings at each end of the spring and no bushing on the frame bracket. That makes sense, since the bushing is creating the correct diameter in the spring eyes. If you had one in the frame bracket, I bet the hole is the right size for the bolt and not for the bolt plus a bushing, so a bushing installed there would have to be cut down and then would just cover the middle of the bolt.
A plastic(/nylon/polyunobtainium/etc.) bushing wouldn't last long under the heavy loading that is present at each hole in the frame bracket.
Old Dec 16, 2023 | 11:33 AM
HRTKD's Avatar
HRTKD
Seems like it should be three bushings for each side. When I upgraded to wet bolts on my two axle setup I had seven bolts/bushings. Eliminate the equalizer and that would be three bolts per axle.
Old Dec 23, 2023 | 09:25 PM
CathedralCub
FTE Community Team
I agree, I think it should be, but the video only showed two. It probably saves them $0.69 per package.
rowdyredneck
1983 - 2012 Ranger & B-Series
Jul 4, 2017 05:52 PM
Baatzy
20
Jan 28, 2016 09:50 PM
smashclash
Jul 26, 2010 11:50 AM
CatBob
Aug 2, 2008 10:49 AM
