Rear Spring Bushings
I have a 1995 Ford F-150 4x4 4.9 5spd. I'm in the process of replacing the rear spring hangers and have run into a problem. I removed the spring eye bushing and haveing a problem finding a replacement for the front eye of the spring. I ordered poly bushings from broncograveyard but the front bushings were too small. Then I got bushings from napa and advance and they are too small for the eye. Are there different size bushings or do I have an odd ball spring? Anyone have a source and a part number.
Thanks
Thanks
I replaced my rear springs and i got a set of polly's threw summit racing the stock spring bushings are a pain to get out but the new polly's installed great. call them and ask if you only want the front ones or the hole kit.
Energy Suspension 4-2114G - Energy Suspension Leaf Spring Bushing Sets - summitracing.com
http://store.summitracing.com/partde...5&autoview=sku
According to Energy Suspensions web-site there were two different styles of bushings for the rear springs. Molded rubber bushings where no outer steel shell was used and rubber bushings that had a steel outer shell.
Are you sure you purchased the proper bushings?
The part number you posted is the wrong one if you have a steel outer shell.
Original bushing is Molded in rubber style. No outer steel shell part number is 4.2140g
Original bushing is rubber with steel outer shell part number is 4.2114g
Click on the link below to go to energy suspensions web-site
Ford Truck Listings Page 5
I have run into similar issue while swapping 93 lightning rear end and suspension to my 96 2wd. Had to cut/burn the old busings out. Went to Advance Auto to get new bushings, but they only sell the larger bushings and not the smaller.??? I have had some other stuff going on and am not able to work on the truck right now, so I hadn't tried to find the bushings any where else yet. Thought it was strange though!
Energy Suspension 4-2140G - Energy Suspension Leaf Spring Bushing Sets - summitracing.com
Energy Suspension 4-2122R - Energy Suspension Leaf Spring Bushing Sets - summitracing.com
matt2491
07-02-2015 01:37 AM
FordFETruck
17
06-29-2015 11:53 AM
Tomahawk
06-20-2014 11:18 PM
