Sponsored by: Real Truck
Battery light on
Old Dec 5, 2023 | 12:37 PM
bnuss25's Avatar
bnuss25
5th Gear
Battery light on
I have a f250 superduty 6.2L. I recently had the battery light come on and the next morning on my way in to work all of the lights and radio went out. I checked the alternator readings and it was overcharging at 16.5-17.5. I changed out the alternator and now charging at 14.8 both at the alternator and the battery but the battery light keeps on. I scanned it and p0625 code comes up. I've cleared the codes but they keep coming back on. Been looking for broken wires and cleaning connections but can't seem to find the problem. Any help would be great
Old Dec 5, 2023 | 02:39 PM
INFRNL's Avatar
INFRNL
did you use an oem or bosch alt? sometimes autoparts store brands will do that. also are you absolutely sure the connector is fully seated, I think that can cause it too. I did that once, swore I had it fully seated but it actually wasn't.
Old Dec 5, 2023 | 03:05 PM
bnuss25's Avatar
bnuss25
5th Gear
Not sure of the brand. I got it from Napa. Pretty sure I got the connector on all of the way but will double check it
Old Dec 6, 2023 | 02:37 AM
INFRNL's Avatar
INFRNL
I got a bosch from Napa, been great for a good 11-12 yrs now, still going strong.
I don't know what else would cause this issue. hopefully the more knowledgeable will chime in
Old Dec 6, 2023 | 08:41 AM
WWR's Avatar
WWR
NAPA is almost surely your problem. OEM will likely fix you up
See this:
https://www.ford-trucks.com/forums/1...ight-on-2.html
You can also read the two links I posted in post #18 above.
OP resolved in post #27 by getting rid of aftermarket alt
This is not isolated problem. You can find at least a total of three threads including the one linked above
Old Dec 6, 2023 | 08:48 AM
redford's Avatar
redford
FTE Leadership Emeritus
Have your battery tested.
Old Dec 6, 2023 | 03:00 PM
99powerstrokedF250's Avatar
99powerstrokedF250
Agree with Redford, if you've been overcharging your battery it's POSSIBLE that it is damaged. It is ALSO possible that the battery was going bad and forcing the overcharge condition to the point where it blew the regulator out on your original alternator. It's a good idea to change batteries every 4-5 years, give or take.
That said, Super Duties tend to not like anything that doesn't have the Ford logo on it. It may run okay with aftermarket parts, but quite often non-OEM electrical components give these trucks heartburn.
Old Dec 6, 2023 | 04:18 PM
bnuss25's Avatar
bnuss25
5th Gear
My battery is about 3 years old and I did test it and it reads good. The napa alternator was charging it at about 14.0-15 volts so I’m hoping that’s why the light is still on. I ordered a oem one and will install it tomorrow and see what happens
Old Dec 6, 2023 | 04:53 PM
WWR's Avatar
WWR
LET US KNOW please!!
When the batt light came on on our '08 F150 I ordered some parts and rebuilt it myself. It's been working fine.....
On my SuperDuty I carry a spare used OEM in the truck box. They can be quite affordable on ebay, but certainly with any used part there's a gamble-- although we know from results new parts are a gamble here, too
Old Dec 7, 2023 | 11:18 AM
bnuss25's Avatar
bnuss25
5th Gear
Swapped Napa alternator for an oem one and same thing. Charging at idle 14.9-15 volts and battery light is still on
Old Dec 7, 2023 | 01:06 PM
bnuss25's Avatar
bnuss25
5th Gear
Found a broken wire that was causing the issue. It was a single wire in a separate canvas type loom right next to the battery
virgil spells
General Diesel Discussion
Sep 7, 2013 12:06 PM
MeolaF250
May 29, 2013 11:52 AM
medic25
Dec 10, 2012 02:20 PM
mgf250
Aug 5, 2010 08:29 PM
jim0517
Jan 8, 2006 07:54 AM
