no can do it died today i was sitting at a light and it stalled i tryed restarting it but all it did was caugh then after 30min it wouldent even do that i had to have towed home today w/ a dead battery from the hazzards changed the fuel filter at the light but that wasn't the problem it had spark because it would caugh but after it stopped caughing i started to wonder did my computer give up on me or did the spark pluges foul up right now i don't have a clue intil i get my computer tester back
This is sounding like it is a fuel issue. Was it smoking any when it died? (black) Pull the air cleaner and make sure it is pumping gas, should see it squirt. If it does than hold the pedal on the floor and try and start it.
just tried that pouring gas in to the carb the truck will run but the carb is not letting the gas flow into the manafold we tryed the float that didn't work i think that carb is beyond help my uncle thinks the diafram or the float but we beat the carb within an inch of its life that didn't help he say to replace the entire thing with a brand new carb not a reman carb
well took it to ford today and found out the lines are bad and both fuel tanks have to be replaced new lines run fuel pump and carb about $800.00 in repairs im not happy
it is getting fuel to the carb but it has a lot of rust in it and gunk from the first tank that i wanted to get replaced in the first place was seeping in to the line (sugar, rust, varnish, water)and the rear is just rusting out
Originally posted by PaulzF150 I had the same problem on my '85. Turns out the computer under the dash was no longer working. I have since converted to DSII.
I thought all 84's were carb(and not those stupid computer controlled carbs)
I had the same problem on mine last winter, it's an 84 5.0L and it ended up being the fuel filter, the symptoms were sluggishness, bogged going up hills, and would only idle after 10minutes of driving at 55mph.
