Intermittent abs light
Old Nov 27, 2023 | 07:00 PM
Jamon Norton's Avatar
Jamon Norton
I have a problem with my ABS light coming on intermittently. From what I have read I am thinking it is a vehicle speed sensor issued. I recently had the rear differential rebuilt and have done two fluid changes on it. If so, is the only way to go on this part or is anybody had luck out of aftermarket and if so, what brand?
Old Nov 27, 2023 | 08:57 PM
udsuth78's Avatar
udsuth78
Check the wiring real well before pulling the trigger on a new sensor. I made that mistakes couple years ago. Turned out to be a broken wire at one of the support hangers between the frame rail and the differential. Wasted money on a sensor when all it needed was 10 cents worth of solder and heat shrink.
luvemhot
15
Feb 7, 2008 04:10 PM
GALAZIO
Apr 24, 2007 08:38 PM
dougwood62
Dec 26, 2006 10:21 AM
JDMONTY77
Jun 30, 2004 09:35 AM
