ABS light on
Old Feb 1, 2008 | 06:43 PM
luvemhot's Avatar
luvemhot
ABS light on
My ABS came on today. Would the culprit be the vss sensor on the rear pumpkin? or is there something else it could be? thanks
Old Feb 1, 2008 | 06:58 PM
dryfly's Avatar
dryfly
that would be my first check.
Old Feb 1, 2008 | 07:03 PM
gunfrk's Avatar
gunfrk
Ditto on the VSS. I gave about 13 bucks at NAPA for mine
Old Feb 1, 2008 | 09:43 PM
Mike Norwood's Avatar
Mike Norwood
try your stealership. mine was actually cheaper than napa by $2. lol
Old Feb 1, 2008 | 10:47 PM
1996pwrstrk's Avatar
1996pwrstrk
Mine came on the other night on the way to work, when I moved my truck at break time it was still on so I goosed it spun the tires about 5' and it went out . It's still out but I'm thinking about getting a vss the dealer down here wants $30.00.
Old Feb 1, 2008 | 11:10 PM
luvemhot's Avatar
luvemhot
my OD light in now blinking, still the vss?
Old Feb 1, 2008 | 11:18 PM
bdrummonds's Avatar
bdrummonds
Given the alternatives, the VSS is still the least expensive thing to try.
Old Feb 1, 2008 | 11:22 PM
luvemhot's Avatar
luvemhot
I will pick one up monday, then lay in the snow and put in, thanks for the help
Old Feb 2, 2008 | 12:14 PM
luvemhot's Avatar
luvemhot
now my speedo dose not work until the tach is at about 1600 rmp. is this still the vss?
Old Feb 2, 2008 | 01:10 PM
WMRiceman's Avatar
WMRiceman
Faulty VSS will cause the speedometer to act up as well.
Old Feb 2, 2008 | 01:47 PM
luvemhot's Avatar
luvemhot
thanks mark
Old Feb 2, 2008 | 02:32 PM
PaysonPSD's Avatar
PaysonPSD
I had all the same symptoms because of a bad VSS, plus a blinking OD light. That's what you will probably see next.
Old Feb 4, 2008 | 06:07 PM
luvemhot's Avatar
luvemhot
The VSS cured all problems thanks to all who helped
Old Feb 4, 2008 | 06:23 PM
dryfly's Avatar
dryfly
Glad that was the problem.Something simple.Thanks for letting us know the fix.
Old Feb 7, 2008 | 03:13 PM
Jack_99V10's Avatar
Jack_99V10
The VSS is in the transmission, the ABS Speed Sensor is in the differential.
Which one did you replace?
